Page 8 of 8 FirstFirst ... 345678
Results 106 to 107 of 107
  1. #106
    Aug 2013
    132
    Ho-lee-crap that is a big machine! You were brave lifting it all off the base like that. Great work so far!
  2. #107
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Thanks Andrew.
    I spent some time running the grinder over the vertical head clamp over the last few days, then finally counterbored the mounting holes. When i had the DH on the mill i also finished the nuts off. Crikey, don't tell me she's nearly done! Not quite yet....
    While the head was out of the way i also bored a 25mm end mill holder out to 1.250" for some endmills i got from Brendan. Damn the holder was hard! The weak link in the setup was the BXA toolpost, i ended up removing the height adjustment screw and putting the toolholder right down on the table. The high frequency chatter was unbelievable before i did that....The end mill holder is an Ann Way branded one from Taiwan tools. Real nice quality, best i have seen out of Asia.
    Ew
  1. Milling machine
    By lamestllama in forum METALWORK GENERAL
    Last Post: 21st Jun 2019, 06:02 PM
  2. Milling machine set ups.
    By 4-6-4 in forum METALWORK GENERAL
    Last Post: 1st May 2012, 03:04 PM
  3. HM 50 milling machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 19th Apr 2012, 07:12 PM
  4. Used Milling Machine
    Last Post: 15th Apr 2012, 10:07 PM
  5. Milling machine
    By paulj in forum METALWORK GENERAL
    Last Post: 8th Oct 2011, 10:14 PM
