Results 46 to 53 of 53
Thread: Bottoming/Plug Taps
27th Nov 2012, 09:41 AM #46Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Sherline Chucks
Just happened to notice the mention of the Sherline Chuck.
Yes, I got the idea of the chuck from Bob.
Its a little beauty!
Used it only yesterday, however have found it a very useful piece of equipment.
I use mine primarily in a Hercus Indexing fixture, the fixture has an internal 3 Morse Taper.
So when I ordered my chuck I purchased it with a rear internal thread of 14mm by1mm to accept a
3 Morse taper male piece which was threaded to 14mm -1mm ( this was a piece I already had )
To ensure it does not come off when machining with milling cutters etc I put a drop of loctite on the threads & also made up a draw bar to hold it in the fixture.
Purchased it direct from the USA mine is a part 1031 2.5" OD threaded 14mm 1mm
Contact is....Bruce's Projects 584.jpg [email protected]
regards
Bruce
27th Nov 2012, 11:59 AM #47
Thanks for that BT,
I have an old 2" Pratt Bernard 4 jaw chuck I bought by
Accident on Ebay that I have just found a use for thanks to
you fellas.
I bought it in its last few seconds thinking it was a 200mm
chuck as the seller had one listed as well, turned out I was in
such a hurry I hit the wrong one.lol
This little 4 jaw looks like it has never been used, so my thoughts
are a setup like yours but I might make it a live chuck.
Again thanks for that.
MattWarning Disclaimer
27th Nov 2012, 09:23 PM #48Most Valued Member
27th Nov 2012, 09:37 PM #49Philomath in training
- 6,562
I'm thinking BA as well. This chart is from an old Blackwoods catalogue - it may be of interest. I think Sutton tools do (or did) a large thread chart too.
27th Nov 2012, 11:33 PM #50.
- 6,459
Stu,
If you think that an 8BA die would help you out, I'll send you one with the Eclipse "upgrade".
I have to ask. What are you trying to fix?
BT
ps. That thread gauge looks like a poor attempt at saw sharpening.
28th Nov 2012, 12:17 AM #51Most Valued Member
Hi Michael,
Thats the sort of thing I was thinking about.
Something that lists most of the common threads by Dia the pitch/tpi.
maybe there are to many to make it much use?
Hi Bob,
I'll try cutting an 8BA tomorrow and see how it goes.
I'm making a special tip for a dial gauge.
Would you believe I have two rolls of tracing paper(though I'm not sure thats really its name) in the shed. Couldnt find it and had to use baking paper on the comparator! lol
p.s. Yes, it wasnt their best work.
28th Nov 2012, 11:34 PM #52
30th Nov 2012, 12:33 PM #53Most Valued Member
- Jun 2012
- SA
- 1,649
cheap taps
Had need of a 10 x 1.25 mm tap today and as usual I have everything except that pitch.
Fairly common small engine crankshaft nut size/pitch, but I seem to be without.
Priced HSS jobs at Gasweld and nearly had a heart attack.
So doing the job another way, BUT bought these cheapies off Ebay - slow boat from China I expect.
eBay Australia: Buy new & used fashion, electronics & home d
Let you know how they turn out
Rob
BA taps
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 23rd Sep 2011, 05:16 PM -
How do you keep taps straight?
By Bidgee in forum METALWORK GENERALReplies: 21Last Post: 25th Dec 2010, 07:56 PM -
Taps & Dies
By footz in forum METALWORK GENERALReplies: 22Last Post: 6th Oct 2008, 07:11 PM
