Results 31 to 45 of 53
Thread: Bottoming/Plug Taps
25th Nov 2012, 08:58 PM #31.
- 6,459
Stu,
I'll post over the shorter fatter Eclipse. Whilst I've whinged about it , it has to be better than those Oriental handles.
My die stocks are all older P & N. I used to use a newish 1" stock, also P & N, and always disliked it. The dies would wobble and a couple of the screws snapped. Then I found the older pair in the photo. They work well.
25th Nov 2012, 08:59 PM #32
I ground off the swage(?) on one end of my little one's tommy bar at one point for some reason. I think I tried mounting it in the drill press for guided tapping. Found that did not work. Not enough grip with the chuck and of the chuck. For a while after I just held the tommy bar on with a bit of plastic hose (tiny). Was probably wire insulation as the bar is only 4mm diam max.
25th Nov 2012, 09:07 PM #33
25th Nov 2012, 09:22 PM #34.
- 6,459
Dean,
You asked about the 2 and 4 jaw "chucks". The 2 jaw holds the tap more rigidly than the 4 saw cuts.
When I was making a little oiler adapter the other weekend, I used a die rather than cut the short M6 thread with the lathe. I did use the lathe for the job but rather than struggle with the die stock held up against the tailstock barrel, a three handed job, I did this -
26th Nov 2012, 12:10 AM #35Most Valued Member
Hi BT,
I better get to and finish off your christmas present then!(though I'm not sure which Christmas it will be for lol)
Thank you
You wouldnt have M2.2 screw over there would you?(at least I think its M2.2 )
Hi Dean the plastic hose sound like a winner.
26th Nov 2012, 08:55 AM #36.
- 6,459
Not here in Boomtown Stu. I was on German Ebay looking for exotica and found these - NSR 804839 Metric Body Screw M 2.2 x 6.5 (10) | eBay
Might be RC shop fare over your way.
BT
26th Nov 2012, 10:43 AM #37Most Valued Member
Yes things are likely to be a little bigger over that way.
Its not M2.2 anyway. Its major Dia is just under 2.2mm but its 60tpi, though if I had to pick a thread form I'd say its BSW......I might just make one lol
Might be time to get out the tracing paper and the optical comparator.
26th Nov 2012, 05:38 PM #38Golden Member
- Cairns, Q
- 666
Stuart,
Not 8BA?
8BA thread spec: OD of screw 2.18 mm, 59.1 TPI, 47.5 degree thread angle, with rounded crests and valleys like Whitworth.
FWIW I was in a bearing supply shop in Atherton last week and noticed he had individual Australian made Sutton 1" diameter button dies up to at least 10 BA in stock. I had been "sort of" looking for some BA dies for a while but I hadn't ever seen these before - usually the modern available BA dies seem to come in model makers' sets in carbon steel and smaller ODs which require a special die holder and haven't impressed me. They were not cheap, ($24 each), but I bought the common sizes of 2, 4, 6 and 8 BA. I don't often need them, but they are very handy to have for the odd occasion when they are needed. If they had been a bit cheaper I'd have bought the full set.
Other than in model making, BA threads were common in pre-metric instruments and electrical fittings. You might be lucky enough to find a suitable 8BA replacement screw in an old electrical fitting, otherwise possibly in a model maker's shop.
Frank.
26th Nov 2012, 08:46 PM #39
Very nice. How did you turn it? Hand turn the main chuck?
I have extended 1/2" W threads for fencing use by using my lathe on slowest speed (16rpm) or maybe the next one (?) and hand holding the die holder. I have one hand on the clutch lever and one on the die holder. I can disengage the clutch and stop the lathe before the handle hits the bed. Its in the gap anyway.
26th Nov 2012, 10:45 PM #40Most Valued Member
Hi Frank,
Thanks, it could be 8BA. Of course I only have 9BA and 6BA, so no quick check. I'll try checking it tomorrow. Though something close will do as its not going to be under much load.
I must make up a thread chart that lists them all by dia and tpi/pitch.
26th Nov 2012, 10:53 PM #41.
- 6,459
Yep, by hand. I just started the thread with the die in the chuck then finished it with a stock. I tried power threading once with a die in a stock. From memory it was an M8 thread on some 4140. The thread was about 90mm long. All turned to xxxx when the die became extremely hot and ended up galling the thread. Yet another lesson learned.
BT
27th Nov 2012, 04:47 AM #42
27th Nov 2012, 08:16 AM #43.
- 6,459
Hi Matt,
It is a little Sherline chuck. It's threaded 3/4" x 16. I turned up a 2 Morse arbor to suit to which I can fit a 3M sleeve enabling its use in the Hercus headstock. It has proved to be extremely handy over the years. Even used it in the Vertex rotary table for milling stuff in my height deficient Hercus mill.
Sherline 1041 - 3 Jaw Self Centering Chuck [3/4 - 16] ...NEW | eBay
Bruce liked mine enough to buy one of his own. Bit of luck he might let us know where he bought it.
Their 4 jaws look neat too.
BT
27th Nov 2012, 08:27 AM #44
I had no issue with heat. I used RTD spray. The dies were 2" P&N. 1/2" Whit is a lot tougher to cut than M8. The MS rods I was using had damaged threads. The ends were seriously mushroomed. I cut the end off which left me with maybe 20 - 25mm of thread. This was then extended to 50 -60mm. I used them to make gate hinges (weld pins on), long bolts etc.
I had hundreds of these rods once. They came from work. Part of a barrel storage method that has been discontinued. Most were burnt. The rods were used to keep timbers in place. I recall seeing an 8ft x 4ft x 3ft bin half full of the complete rods pulled from the fire after a burn. The galv was burnt off and all rusty by then. Sometimes the stupidity of people in this world defies belief. Most of what I had have been used up.
27th Nov 2012, 08:45 AM #45.
- 6,459
Dean,
The heat would have been generated as a result of the bar being too large at 8mm. Being book informed I did not realize that the diameter should have been undersize. I had machine cut the thread. I was using the die to clean the thread up.
Bob.
BA taps
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 23rd Sep 2011, 05:16 PM -
How do you keep taps straight?
By Bidgee in forum METALWORK GENERALReplies: 21Last Post: 25th Dec 2010, 07:56 PM -
Taps & Dies
By footz in forum METALWORK GENERALReplies: 22Last Post: 6th Oct 2008, 07:11 PM
