Results 1 to 15 of 18
Thread: Key Removal
13th Nov 2012, 04:15 PM #1Banned
- Feb 2012
- 73
- 153
Key Removal
The gear cluster (not shown) that slides along the keyed shaft is binding on the left side of the shaft so I need to turn the shaft down a smidgen; however, I can't get the key out to remove the bush (left of the key), any ideas?
13th Nov 2012, 04:36 PM #2Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,954
Pincers
http://www.hyperclaw.com/pic/products/carpenter-pincer-1-L.jpg
If it's binding, it might be the key itself that needs filing down a bit.
Jordan
13th Nov 2012, 05:21 PM #3Most Valued Member
- Jun 2012
- SA
- 1,653
Turn the shaft so the key is facing down, then use the corner of a small cold chisel on the side near one end to knock it out.
It will come out easily.
You will mark the key but that won't matter, just sand off the burr and you're good to go.
Rob
13th Nov 2012, 07:47 PM #4Banned
- Feb 2012
- 73
- 153
Pincers
I have tried a chisel (ground down because of limited space), but only stuffed the end of the key. I also tried a large jeweller's screwdriver and a pair of modified vice grips, also no luck, just stuffed a few screwdrivers. I'll try a pair of pincers next, never thought of that....
13th Nov 2012, 07:52 PM #5Banned
- Jul 2011
- Melbourne Australia
- 1,376
You wouldn't happen to have a little tool makers vice? They are great for clamping onto a key, then giving that a bit of soft hammer action.
Phil
13th Nov 2012, 10:35 PM #6Pink 10EE owner
- 6,240
Last resort option is to weld something onto it that you can really grab... Although I have never had to resort to doing that yet.. Drill and tap the key is another option if all else fails...
13th Nov 2012, 10:56 PM #7
shrinking
I wonder if shrinking it would help. Buy a pressure pack can of that loctite freeze stuff and spray the stuck key for a minute Mike
13th Nov 2012, 10:57 PM #8Golden Member
- Mar 2009
- 55
- 826
Not sure if this is what RC meant or not but if you drill into the key towards one end, enough to just go through the key itself then screw in a bottoming tap it should push it out when you reach the bottom.
If not then withdraw the tap and replace it with a screw or bolt for a bit more grunt.
Greg.
13th Nov 2012, 10:59 PM #9Banned
- Jul 2011
- 1,376
13th Nov 2012, 11:26 PM #10China
- Dec 2005
- South Australia
- 1,681
Tap one end with a brass or copper hammer sometimes this will cause the other end to lift, or can you heat the shaft the then lift it out with pliers or similar
14th Nov 2012, 08:56 AM #11Mechanical Butcher
- Oct 2004
- 1,954
14th Nov 2012, 09:13 AM #12Most Valued Member
- 4,973
Most if not all large captivated keys have one or more threaded holes for removal,and most keys with restricted access with have them as well.
14th Nov 2012, 09:30 AM #13.
- 72
- 6,460
Maybe another option?
Years ago I saw a bloke selling a slide hammer attachment for vice grips. A quick search revealed he is still around - Slide Hammer Vise Grip Puller Made to Fit Snap on Mac Size LG | eBay
It would not be hard to make your own version of this useful tool.
BT
14th Nov 2012, 11:59 AM #14
I wonder if someone may have used Loctite to "glue" it in? So may be a little heat, would soften the key's grip?
It could be a victim of the Quantity Principle-----"If some is good, more has to be better"
A mate who is a very good mechanic did his apprenticeship at a tractor repair place where he saw all kinds of nasties. He has come away with the philosophy that farmers should not own a welder (Bus driver had trouble with drivers front wheel coming loose) or a chainsaw.Just do it!
Kind regards Rod
14th Nov 2012, 06:24 PM #15Golden Member
- Cairns, Q
- 666
