Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Ueee's Avatar
    Dec 2011
    Canberra
    40
    4,515
    Wouldnt two sides do?*
    But point taken on the infeed side of things. Spot on it is then. Though adjustable feet will still be needed unless the floor is flat.
    *Though two other sides would be twisted I dont think it would show up in the diagonal unless R&J were doing the measuring
    the way its working in my head if you have 2 sides out of square they have to be in the same plane so you have a parallelogram. I used to be all over this sort of stuff when i was a cabinetmaker full time as it has everything to do with door alignment.
    Like they say, if you don't use it you loose it.
  2. #17
    Jul 2010
    9,096
    Put a cube on the ground, Lift one corner. two square flat faces, two flat parallelograms faces and two square* twisted faces.
    I think
    *Ok not 100% square as the lifted corner will have come in a little.
    Exactly, thats why I like to run these things through my soggy grey matter.
  1. Nesting steel square tube
    By Lyle in forum METALWORK GENERAL
    Last Post: 27th May 2011, 04:14 PM
  2. Replies: 9
    Last Post: 2nd Jul 2009, 11:12 AM
