Results 1 to 15 of 33
Thread: Dividing plate for 127 divisions
24th Oct 2012, 04:31 PM #1
Hi All,
Some time ago Michael G offered to drill a dividing plate with 127 holes for those of us with RT's and basic dividing heads. I have had the 127 hole "steering wheel" for a few months now, but i finally got around to boring and mounting it, and making a new arm to hold the spring loaded detent pin. I used the pin from the purchased dividing set, which is held in with a grubscrew and a "light" interference fit. I just have to make a sector arm so that i can easily move the 90 holes required for each indexable point.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
24th Oct 2012, 05:10 PM #2Philomath in training
- 6,559
Looks good so far.
If you made up a link out of say 1mm steel with a hole in each end that was (127-90=37) holes (chord length) apart, you could swing it around in the opposite direction to the crank rotation to get the right spacing. Once you had indexed, the link could just hang on the plunger tip until needed again. For those with a 40:1 ratio I'd use a 40 hole spacing.
7th Nov 2012, 08:42 PM #3
I started on some gears this arvo. Over the last few days i have made up a mandrel for the gears and arbor for the gear cutters. I am using M1.5 for all the new gears, using 14dp to match the existing gear would mean the 127 and 120t gears would be too big to fit on the banjo.
I bought a small sheet of 12mm acetyl (Delrin) to cut the bigger gears from, cutout the blank with the jigsaw and took to boring and turning them. At 193.5mm in dia and 820rpm i was cutting at 1630f/m....The pic of the shavings all over the place says it all
My $5 8-9" mic came in handy too, with the use of a 1" gauge block it was the only way i could measure the dia accurately.
7th Nov 2012, 09:50 PM #4Most Valued Member
- 4,890
Would of thought you blokes with all the measuring gear would of had the right size mic or vernier or even a pye tape.
7th Nov 2012, 10:30 PM #51915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
7th Nov 2012, 10:48 PM #6
faceplate
Hi Ewan
How come the faceplate is there ? how is the mandrel supported ?
7th Nov 2012, 10:56 PM #7
Hi Mike,
the faceplate is only there so the spindle nose is not bare (not that plastic is going to effect it, but the last thing you want is lots of chips in your thread to have to clean out), and it also adds a flywheel. The Mandrel is in an ER40 collet in the spindles taper. I will use the same mandrel to hold the blank to cut the teeth on the mill. I made the mandrel from an old holden? axle, it can hold up to 5 gears at once, it is 3/4" dia, the thread and nut is M16 fine (1.5mm) cut the hard way without my automagical stop.1915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
8th Nov 2012, 07:37 PM #8Most Valued Member
- Healesville
- 2,129
Nice work as usual Ueee
I spoze that if a "bloke" actually owned a Pi Tape himself then he would know how sssspeeel it
9th Nov 2012, 09:30 AM #9Senior Member
- Jan 2010
- 119
Last edited by markpest; 9th Nov 2012 at 09:35 AM. Reason: ? character was incorrect
9th Nov 2012, 09:39 AM #10Senior Member
- Jan 2010
- 119
21st Nov 2012, 08:30 PM #11
I have started cutting gears...what a dull job! with the delrin it takes about 30 sec per tooth, i would hate to be doing steel. I ended up making a sector arm out of .6 gal. I was going to drill holes on it for the spacings as Michael suggested, but if i had done it that way i would not have been able to rotate for the next spacing without pulling the detent pin out. Cutting delrin on the mill is not fun.....there is snow everywhere, even with the vac in use.
21st Nov 2012, 08:51 PM #12Philomath in training
- 6,559
I think the worst part about doing large steel gears is the noise as I find they ring like crazy. (The utter boredom is the next thing of course).
I like the sector - a neat solution.
21st Nov 2012, 10:44 PM #13Most Valued Member
Hi Ewan,
Looking good.
Shame about the snow.
5th Dec 2012, 11:01 PM #14
I am now done cutting gears, so the 127 hole dividing plate is available for anyone wanting to cut there own metric/imperial transposing gears.
I have started working on new "holders" (i'm sure they have a proper name) for the gears on the banjo, i was worried about a key not being enough in the delrin so i went with 2 5mm dia pins with knurled nuts to hold the gears on the bearing. Now i just need to make similar holders for the driving gear and leadscrew gear. It will be interesting to see how well the smaller gears hold up and how quiet they will be.
1st Jun 2013, 01:00 AM #15
Its only been 5 months.......
I stopped this project as i ran out of 50mm bar, and it was in making the banjo spindle that i crashed the Mars and that lead to the rebuild.....
Anyway, i picked up some bar earlier this week and it is all finished now, except of course working out what other gears i need.....
I made it all to be as tool-less as possible, i only need one size allan key (and myself) to adjust the banjo and the spindle for the middle gears. I also made the spindle so it was adjustable from the outside, a SHCS goes right through the spindle and into the t nut to clamp it in place.
The gears are much quieter than the cast ones, and changing them is much quicker than it was. I'm still tossing up between a simple QCGB and going to a separately powered feed shaft. Maybe i should make both just for the fun of it
dividing plates, dividing head
By eskimo in forum METALWORK GENERALReplies: 22Last Post: 4th Aug 2012, 06:17 PM -
Dividing Plate advice needed
By Poloris in forum METALWORK GENERALReplies: 6Last Post: 3rd Jun 2012, 12:43 AM -
Hercus Dividing Head - Division Plate
By Anorak Bob in forum THE HERCUS AREAReplies: 16Last Post: 25th Feb 2011, 11:27 AM
