Results 1 to 15 of 16
Thread: Slow starting motor
2nd Oct 2012, 03:09 PM #1Senior Member
- Oct 2010
- Newcastle Australia
- 66
- 122
Slow starting motor
I have a single phase motor which I disassembled and reassembled.
When I go to start it, it starts very slowly and with a bit of encouragement it will hit top speed.
Inside is a set of points, I think I have incorrectly repositioned the bearings and as a result
I think the points are staying permanently open.
Would this be the cause of the very slow starting even when there is no real load?
2nd Oct 2012, 03:23 PM #2
Yes, if it's cap start cap run, and the start cap centrifugal switch is open it will do that. Check that the centrifugal switch is working properly.
2nd Oct 2012, 03:39 PM #3Senior Member
- Oct 2010
- 66
- 122
I'd say I misaligned the bearings by about 12mm. So the rotor and stator are misaligned by about the same amount.
I've added to my grief by Loctiting a heavy cast iron pulley to the 1" shaft and it won't budge.
So I'm thinking of putting a spacer behind the bearing to get the points working.
But...will I lose much power with the misalignment within the motor itself?
2nd Oct 2012, 04:01 PM #4
How many capacitors does it have? one or two?
2nd Oct 2012, 04:07 PM #5Senior Member
- Oct 2010
- 66
- 122
2nd Oct 2012, 04:33 PM #6
The circuit should look like this..
With the centrifugal switch permanently open, the power (when it finally gets going) will be the same, but you won't have much starting torque.
2nd Oct 2012, 04:38 PM #7Senior Member
- Oct 2010
- 66
- 122
2nd Oct 2012, 04:44 PM #8
2nd Oct 2012, 05:00 PM #9Senior Member
- Oct 2010
- 66
- 122
2nd Oct 2012, 05:53 PM #10
Don't really know how much power you will lose, maybe not much?, but I think you should pull it apart and re-assemble it anyway.
2nd Oct 2012, 07:14 PM #11
I am still not quite following how it is misaligned, but if the rotor is not lined up with the stator i guess you will loose as much as a percentage of power that the 12mm equates to as a percentage of the rotor length.
3rd Oct 2012, 08:42 AM #12Senior Member
- Oct 2010
- 66
- 122
3rd Oct 2012, 08:58 AM #13Most Valued Member
- 4,258
3rd Oct 2012, 09:47 AM #14Golden Member
- Dec 2011
- 505
3rd Oct 2012, 10:59 AM #15Senior Member
- Oct 2010
- 66
- 122
The pulley is probably 100 years old (slight exaggeration) and the centre was slightly flog out and it was impossible to
keep tight on the shaft and imparted a slight vibration to the head. I found by Loctiting, the vibration was almost gone.
The grade was 263. I have applied a good amount of heat to it and got it to move about 2mm.
So the plan is to drill and thread three holes into the pulley and use some flat plate and a bolt to make up a puller and apply the heat...
should work.
Someone said acetone might soften the Loctite so I might check that out as well.
On a go slow
By A Duke in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 55Last Post: 7th Feb 2012, 11:24 AM -
Slow Tonight?
By craigb in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 13Last Post: 6th Nov 2005, 09:36 AM
