Results 1 to 6 of 6
Thread: Morse Taper Slipping
19th Sep 2012, 06:29 PM #1
I have a 3/4" drill bit that is MT2 and it slips (spins) sometimes in the MT2 taper in the tailstock of my 9" hercus, it is only this particular drill that does it, would anyone have a fix or remedy for it. The RPM of the headstock is the second slowest with the back gear engaged. The material being drilled is mild steel.
Shane
Got the square peg in the round hole, now can't get it out !!
19th Sep 2012, 06:32 PM #2Philomath in training
I'd try bluing up either the taper or the socket and see what the contact area is like. It may be that there is some slight damage that is preventing good seating.
19th Sep 2012, 06:41 PM #3Most Valued Member
- 4,890
Put a lathe drive dog on the drill shank,let it rest against the cross slide or tool post,it wont slip in the tailstock.
19th Sep 2012, 07:14 PM #4.
- 6,459
20th Sep 2012, 07:35 AM #5
Thanks gents for the help.
Shane
21st Sep 2012, 12:50 AM #6Most Valued Member
You could put it in a split tube and turn it, if it is damaged. Read it in a Model Engineers Workshop recently. He had a drill bit with a No3 morse and a broken tang, and turned it down to a No2 with no tang.
Releasing morse taper
By jvdv in forum METALWORK GENERALReplies: 9Last Post: 24th Oct 2007, 04:01 PM -
Morse Taper Turning
By jvdv in forum METALWORK GENERALReplies: 46Last Post: 13th Sep 2006, 03:26 PM
