Results 16 to 20 of 20
Thread: Liquid metal in a tube...
1st Sep 2012, 12:08 PM #16
...after thinking about the hassles of going to bunnies and stuffing around with epoxy as a test, and see how long it lasts, I will go with a screw.
I'll use a gal roofing screw with a dowel shoved up the round section to give a bit more bite for the screw.
The dowel will split thus giving more bite into the inside of the round section.
Hope I have explained it well enough.
If the screw corrodes the ali too much then a re weld will have to happen down the track.
1st Sep 2012, 02:43 PM #17Most Valued Member
- 70
- 1,513
Ever seen what gal tool boxes do to alloy ute trays?
Nev
1st Sep 2012, 05:36 PM #18
...nope.
Only had one aly tray with painted gal tool boxes sitting on timber cauls in the tray.
The rest of my utes had hardwood floors. Apart from the discolouration...what else?
As I said, I aint no metalworker, been a chippy for 30 odd years though, could tell ya a bit about that, ifn ya want.
Glenn
1st Sep 2012, 06:08 PM #19Most Valued Member
- 70
- 1,513
The gal (zinc) will react with the alloy and eat right through it if in direct contact. I'd imagine a gal screw will do the same to your alloy fence.
Nev
1st Sep 2012, 08:25 PM #20
There are painted roof screws available. Any colorbond colour you desire probably. I have galv ones and painted ones in a grey very similar.
It is a toss up which would be worse, galv or stainless. Galv I would say but I was warned about Ali and stainless together when rebuilding a 16ft catamaran. Generally ok but can be a big issue as I said, in salt water. So if wet bodies drip water on the gate on the way to somewhere else?
I say go with what you have and keep an eye on it.
Vertical Storage of Metal Tube and Bar
By Blu_Rock in forum METALWORK GENERALReplies: 7Last Post: 2nd Jan 2009, 09:21 AM -
Aluminium Metal tube
By brandon26 in forum METALWORK GENERALReplies: 2Last Post: 6th Jun 2006, 09:50 AM
