Results 1 to 13 of 13
Thread: Al960 qctp
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default Al960 qctp
    how does one get the existing tool post bolt out...i have tried but am unable to undo it....I am concerned to use more force than I already have...
    is it lock tighted in?
    lather Guest
    lock up 2, M16 nuts (or others depending on the thread) on the bolt, then loosen the post bolt from the lower nut.
    edit:
    the original bolt took some force to remove.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    If thats the case ,and you intend to use a new stud,it might be quicker to just put a pair of stillsons on it.
    if there had of been loctite which there isnt then a little heat would of been an advantage.
    Jul 2006
    Athelstone, SA 5076
    4,258
    I have done that Lather.
    I didnt think it would be as tight as it...so I am worried I might break something if I used more force....it definitely wouldnt be a LH thread would it?
    And thats why I asked Pipeclay...if I needed heat to melt the loctite..(spelt it right this time)...but if it shouldnt be put in with Loctite, I dont need heat
    near Rockhampton
    6,217
    I think my lathe had a nut underneath to undo first, then screw it out...
    Jul 2006
    Athelstone, SA 5076
    4,258
    I didnt look underneath but from feeling it it felt as though it was just screwed in...no nut felt it just feels like a hole...
    I wonder if a grub screw is screwed up from the bottom to lock it?...I'd better have a look
    lather Guest
    if it's the 960b model which the bolt screws directly into the top slide, it's a normal thread.
    needed to tighten the 2 M16 nuts very tight using 2 12" shifters to stop the nuts turning when trying to loosen the bolt.
    was surprised at how tight it was, using a hammer on the shifter should loosen it up.
    Jul 2006
    Athelstone, SA 5076
    4,258
    thanks lather
    i'll send you the bill if the top slide cracks???
    I'll give it another try then...15' shifters this time and after I've eaten my weetbix
    lather Guest
    Check the bottom of the bolt before trying it, as they could have changed the design.
    May 2010
    tasmania
    96
    Mine wasnt super tight - I just used two nuts on the top and out she came. Def not LH thread!
    Jul 2006
    Athelstone, SA 5076
    4,258
    it has thread all the way thru the top slide.
    I might make some time latter this week and take the slide off before having another go. i dont want to break something
    May 2010
    tasmania
    96
    You may recall a prev thread about this from 2010.
    http://www.woodworkforums.com/f65/qu...12/index6.html
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by rfurzer View Post
    thanks rfurzer...i had forgotten about that
  1. my new AL960 cutting a taper
    Last Post: 3rd Feb 2012, 08:31 AM
  2. AL960 Lubrication Questions
    By ozredwine in forum METALWORK GENERAL
    Last Post: 5th Jan 2012, 12:49 AM
  3. AL960 funny noise
    By rfurzer in forum METALWORK GENERAL
    Last Post: 12th Dec 2010, 09:11 PM
  4. al960 b woes
    Last Post: 27th Oct 2010, 10:21 PM
