Results 1 to 7 of 7
Thread: Ebay Diamond wheel dressers
17th Aug 2012, 09:41 PM #1Senior Member
- May 2012
- Vermont 3133 Victoria
- 248
I am looking at picking up a grinding wheel dresser for the surface grinder. Has anyone purchased one off Ebay, 6 to 10 $ ( China & Hong kong ) Are these total junk and a waste of money( small as it is ). If they are not an option, any thoughts.
In the Elliott lathe clean up I decided to skim the compound up on the surface grinder, first time I have used it, the finish is ok but obviously I need to dress the wheel for the final lick.
Cheers bruce
17th Aug 2012, 10:11 PM #2Most Valued Member
I ordered a 1/2 carat single-point diamond dresser on eBay last week. It was about $8 delivered. It looks exactly like the one Carbatec sells for $21. I'll let you know how it works when I get it.
17th Aug 2012, 10:24 PM #3Senior Member
- Jun 2012
- Germany, Outback of Munich
- 211
I have a few cheapish dresser. They all work fine. But I don't use them on a daily basis.
Don't forget, that you should rotate the dresser every once in a while.
Nick
17th Aug 2012, 10:28 PM #4
How are you going to mount the diamond in order to true the wheel? I have two single point diamond dressers; one about 5" long and 1/2" dia which I use for truing bench grinding wheels by hand, the other is slightly thinner only 1 1/2" long and designed to be used in a dressing jig mounted on the surface grinder. The number of surface grinders I've used is pretty low but every one of them had a special truing jig or device that allowed me to accurately flatten or shape the wheel.
17th Aug 2012, 10:40 PM #5Senior Member
- May 2012
- 248
G'day,
I will make up a holding fixture at an inclined angle of 15 as that is what I have seen is the most common. Unfortunately no Mag chuck so I will attach directly to the table. Anyone has a mag chuck they need to move on?
Cheers Bruce
17th Aug 2012, 10:49 PM #6Senior Member
- Jun 2012
- 211
The most accurate way is to mount the dresser onto the table.
Except you want to grind some profile (-> Diaform dresser). Of that dresser, there are ones that are mounted on the table or ones that are mounted near the spindle.
Nick
17th Aug 2012, 11:08 PM #7Most Valued Member
- Jun 2012
- SA
- 1,649
I also have a cheap half carat single point dresser from Ebay which I use for my tool post grinder.
Had it for about 5 years and totally excellent - does a perfect job.
As stated, you must have a jig for an accurate pass across the stone.
Rob
Diamond wheel defect - safe?
By Bryan in forum METALWORK GENERALReplies: 16Last Post: 25th Apr 2012, 05:04 PM -
Anyone qualified to compare wheel dressers?
By billrule in forum METALWORK GENERALReplies: 17Last Post: 20th Jan 2011, 09:34 PM
