Results 1 to 10 of 10
Thread: Internal threading help
7th Aug 2012, 10:02 AM #1Member
- Jun 2009
- Cootamundra
- 73
Hi
I've got a M24 coarse bolt and I need to bore and thread a nut to fit it. How do I calculate the correct size hole to bore in the nut?
TIA
7th Aug 2012, 10:04 AM #2Philomath in training
That information is in a Zeus book.
For M24, core diameter is 20.3194mm; tapping drill size is 21mm
7th Aug 2012, 10:08 AM #3
Tapping drill size is 21mm
Ashore
The trouble with life is there's no background music.
7th Aug 2012, 10:10 AM #4Member
- Jun 2009
- Cootamundra
- 73
Thanks. I should have it clear I'm single pointing the internal thread. Is the hole the same dia as for a tap?
7th Aug 2012, 11:45 AM #5Most Valued Member
- 4,890
Depending on the class of fit (how much clearance you want or need for the bolt or the application your using it in) your bore should be anywhere from 20.752mm to 21.382mm.
7th Aug 2012, 11:48 AM #6Member
- Jun 2009
- Cootamundra
- 73
7th Aug 2012, 12:38 PM #7Most Valued Member
- 4,890
There are charts for standards of fit but if this is just for a standard application I would either go either with the middle of the tolerance or if you wanted go towards the larger .
Seeing you allready have the bolt it might be better to go towards the smaller bore size as production bolts generally have the greater clearance.
This is the reason why a lot of times bolts and nuts bought through hardware and engineering supplies of feel loose.
If you went with 20.8mm to 20.9mm it might make the nut a better fit.
Either way if you go you should be fine.
7th Aug 2012, 12:53 PM #8Dave J Guest
Here you go
http://www.woodworkforums.com/f65/ch...ml#post1466509
Dave
7th Aug 2012, 02:24 PM #9Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,898
For 60 degree threads like your M24, as a rule of thumb:
Major diameter minus pitch = Minor diameter (hole size)
24mm - 3mm = 21mm
Jordan
7th Aug 2012, 08:28 PM #10Senior Member
- Jun 2012
- Germany, Outback of Munich
- 211
If the bore is too small, the peak of the nut's thread rubs against the valley of the bolt. This only pretends a close fit. In fact, the chests of the threads don't get in contact. It's just a misfit.
Nick
Threading again
By morrisman in forum METALWORK GENERALReplies: 18Last Post: 10th Dec 2011, 03:16 PM -
What speed for internal threading
By jackaroo in forum METALWORK GENERALReplies: 16Last Post: 15th Nov 2010, 03:15 PM
