Results 1 to 2 of 2
Thread: Milling attachments.
5th Aug 2012, 06:54 PM #14-6-4
- Mar 2009
- 260
Greetings chaps, I have just posted this in another thread in this forum But I thought that other milling machine bods might be interested. It is a small jacking set. It is pretty self explanatory. There is a base angled at one end Drilled and tapped and slotted at the other. The two different length extensions are Hex. The extension screws were made out of metal threads. I have found that the hold down set for mills tend to fall int the tee slots od this was a solution. The slot in the base was so they could be clamped down for repeat set ups. Hope this is interesting. Yours 4-6-4
5th Aug 2012, 06:56 PM #24-6-4
- Mar 2009
- 260
Hold down
Sorry chap here is the pic for the above thread 4-6-4
By pfisher in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 20th Jan 2007, 05:58 PM
