Results 1 to 5 of 5
    Mar 2009
    BATEMANS BAY
    10
    Default c model sheraton pics
    Hi folks would anyone have any good pics of a c model sheridan lathe (not the quick change gearbox type ) please i need to confirm some parts thaks wayne
    Jun 2007
    sydney ( st marys )
    64
    4,890
    If you cant find suiyable pictures here look at the Southbend lathes,the Sheraton is probably a closer copy than the Hercus,particularly with the drive.
    Most other parts are interchangeable between the 3 machines.
    Apr 2009
    Wollongong
    14
    Quote Originally Posted by warnie100 View Post
    Wayne,
    What do you want pictures of? I don't have pictures but I do have a lathe and a camera. Only problem is that my lathe is being moved tomorrow and will be scattered around in pieces for a couple of weeks until the workshop is finished.
    Greg
    Mar 2009
    BATEMANS BAY
    10
    Default c model pictures
    thanks the inside of the apron and some specs on the lead gear that attaches to th hand wheel spindle i am missing that cog and need to know how many teeth both on the inside and thepart that goes to the rack thanks wayne oh and if you have a manual would you mind if i could get a copy thanks wayne
    Apr 2009
    Wollongong
    14
    Wayne,
    I wasn't planning on taking it apart, and now there is no workshop for me to to do it in. As for the manual, I have never seen a Sheraton manual. It will be a month or so before I can play with it.
    The Sheraton parts should be very similar to the South Bend ones.
    A probably relevant parts list is here http://www.wswells.com/partslist/902D.pdf the model c part would be AS76NK1
    The part you are talking about is probably very like this one South bend 9" 10K lathe apron gears assy AS76NK1 (the Southbend Model C part is different to the part for models A and B)
    or
    SOUTH BEND 9 IN/10K LATHE PINION GEAR AND STUD ASSEMBLY PART #AS76NK1 | eBay
    There will be someone here who either has or knows that part, this is that kind of place.
    Greg
  1. hercus model A 1951 model
    By pjh4159 in forum THE HERCUS AREA
    Last Post: 21st Aug 2011, 03:15 AM
  2. run out on Sheraton model A
    By morrisman in forum THE HERCUS AREA
    Last Post: 21st May 2011, 01:04 PM
  3. Sheraton Model AM Spindle removal?
    By Com_VC in forum THE HERCUS AREA
    Last Post: 14th Apr 2011, 06:02 PM
  4. Found a Sheraton Model A
    Last Post: 22nd Mar 2010, 12:41 PM
