Results 1 to 5 of 5
Thread: Huanyang VFD - SPDT for/rev
16th Jul 2012, 12:29 PM #1New Member
- Mar 2011
- USA
- 2
Hi all,
Can anyone help me figure out how to hook up my VFD to a forward/reverse switch?
The VFD is a huanyang 1.5kw, and the switch is a SPDT toggle switch. There are 3 connections on the back, but no wiring diagram came with it.
I tried connecting the leftmost connection to FOR, rightmost connection to REV, and the middle connection to DCM (top row). The switch doesn't do anything. I then tried the middle connection to DCM (bottom row), again nothing. Then, I tried the middle connection to +24V. Again, nothing.
I set pd023 to 1 (allow reverse). When I press the jog button on the front of the VFD, I can make it go in reverse no problem.
What am I missing?
Thanks,
Lee
16th Jul 2012, 02:14 PM #2Most Valued Member
Hi Lee,
I haven't seen a vsd with two DCM terminals*.
PD001=1?
I hope that switch has a center off.
* but I havent seen that many VSDs
16th Jul 2012, 08:05 PM #3I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
You need to change a setting in the Huanyang VFD to allow switching from an external source (as opposed to using the front panel). Can't remember which setting that was though, will see if someone tells you what it is before I find it in the manual (gotta find the manual first!)
16th Jul 2012, 08:09 PM #4I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
So, I found the manual - turns out Stuart has already given you the answer. PD001 needs to be set to "1" for using external switching. Note that the front panel of the VFD won't work for selecting forward/reverse anymore - at least mine doesn't...
16th Jul 2012, 10:07 PM #5New Member
- Mar 2011
- USA
- 2
Got it working, thanks.
I swapped the switch for an on-off-on switch, and reset to factory defaults. Went through setup again, and set pd044 to 1. Bingo
Huanyang VFD earthing
By morrisman in forum METALWORK GENERALReplies: 5Last Post: 6th Apr 2012, 10:54 PM
