Results 16 to 30 of 44
Thread: Machining text books
12th Jul 2012, 02:40 PM #16Most Valued Member
Might be cheaper from RMIT depending on postage, thats where I got mine but it was awhile a go.
Fitting & Machining - RMIT Publishing
Not cheaper than bigsheds though.
12th Jul 2012, 02:52 PM #17
Not strictly a book, but Model Engineering Workshop is quite a good read. based on peoples projects, with some articles on basics. I just subscribed to the online version and I have access to even the back issues. Slowly making my way through them.
12th Jul 2012, 03:01 PM #18
Depends on what your actually looking for. I've got a very old edition of the machery handbook because the stuff I care about doesn't change. I got it on ebay for about $20 delivered, much better than $200!
But it's a reference book. If your looking for reading material and examples I don't know sorry. I am used to using the texts I learned on so I just go back to them.
I do have a text on mechanisms which I find very handy. It gives examples of each machine and coupling so you can accomodate any sort of movement, but I forget the name. I'll look tonight if your interested.I'm just a startled bunny in the headlights of life. L.J. Young.
We live in a free country. We have freedom of choice. You can choose to agree with me, or you can choose to be wrong. Me.
12th Jul 2012, 03:07 PM #19
Abe
ABE lists a lot of out of publication books like this : Some of these books on ABE are used library books and they are much cheaper than new books .
Lubricants, Cutting Fluids, and Coolants by Olds, Wilbert J.: Cahners Books, Boston, Mass 9780843608120 Hardcover - Abyssbooks
12th Jul 2012, 10:17 PM #20Golden Member
- Mar 2010
- Nth Qld
- 687
Bryan, I have
1-6 Scraping
3-1 The Lathe
3-2 Preparing for Lathe Work
3-3 Turning Between Centres
3-4 Turning between Centres 2
3-5 Machining in a chuck or with a face plate
3-6 Thread Cutting
3-7 Special Lathes
4-1 Shaping
4-2 Shaping 2
4-3 Slotting
6-1 Milling
6-2 Milling 2
6-3 Working with the milling machine
6-4 Indexing
Other titles I don't have are:
1-1 Intro to metalworking
1-2 Hand Tools
1-3 Measuring Testing and Marking Out
1-4 Limit Systems, Tolerances and fits
1-5 Filing
1-7 Drilling
1-8 Off hand Grinding
1-9 Hand tapping and Thread Cutting
1-10 Basic Fitting Projects
1-11 Workshop Safety
2-1 Plane Geometry
2-2 Solid Geometry 1
2-3 Solid Geometry 2
5-1 Grinding Machines and Their Wheels
5-2 Cylindrical Grinding
5-3 Surface & Tool Grinding
Series 10 & 13 are Sanitary Plumbing and Bricklaying respectively
Anyone know someone in the Aust Gov't Publishing Service to get permission to copy?.
12th Jul 2012, 10:34 PM #21Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Mark you've lost me. Are they sections from a later TAFE book? They don't coincide with my 1986 volume 1, though very similar material would be covered. Your edit makes them sound like separate titles.
12th Jul 2012, 10:37 PM #22Most Valued Member
- Sep 2011
- Ballarat
- 3,103
12th Jul 2012, 10:41 PM #23Golden Member
- Mar 2010
- Nth Qld
- 687
The ones I have are TAFE books from 1976 published for the Department of Employment and Industrial Relations by the Australian Government Publishing Service. Yes they are separate titles about 60 pages each. My Local TAFE library turfed out a full set as they said something about "Needing to keep the books turning over and these ones weren't being borrowed enough"
http://trove.nla.gov.au/work/7310112...sionId=8409793
12th Jul 2012, 10:52 PM #24
books
These are my three: 6th edition 1985
12th Jul 2012, 10:55 PM #25Golden Member
- Mar 2010
- Nth Qld
- 687
12th Jul 2012, 10:58 PM #26Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Interesting. I guess the books evolved from those course notes, and the 3 books later converged. My vol 2 is the same as Phil's, my vol 1 is similar vintage and looks later than Phil's vol 1.
Phil are those your own copies or are they the ones that are available? I guess there won't be much difference between editions of the 3 volume version. That's why I said any vol 3 would do.
Mark, thanks for the kind offer. Sourcing the third book would be the simplest solution. If I were starting again I would just buy the single volume edition.
Hope this is not derailing Mike's thread too much.
Edit: Mike's V1 is the same as mine. Dunno what the lathe is but it looks like the same one in the line drawing on Phil's V1.
12th Jul 2012, 11:01 PM #27
I only have Vol 1, the same as Phil has, it is a 1979 edition.
12th Jul 2012, 11:02 PM #28
12th Jul 2012, 11:09 PM #29Member: Blue and white apron brigade
No one has mentioned the 3 volume "Workshop Technology" series by Chapman. A little dated (published in the 1970s) I see copies of volume 1 are still available - even brand new copies! but volumes 2 and 3 are rarer. PDFs of part one are also available.
These books cover just about everything in a metal shop and are my goto reference for just about everything I do. They are also relatively easy to read.
12th Jul 2012, 11:21 PM #30Golden Member
- Mar 2010
- Nth Qld
- 687
Free Old Books - Metalwork Books- Woodwork Books - Engineering Books - Mechanics Book
By crowie in forum METALWORK GENERALReplies: 12Last Post: 1st Jul 2012, 09:39 PM -
Where is the text?
By neksmerj in forum METALWORK GENERALReplies: 15Last Post: 18th Dec 2009, 07:01 AM -
Old Machining books - download
By MacPuddock in forum METALWORK GENERALReplies: 2Last Post: 16th Aug 2008, 11:15 AM -
In text pictures
By jmk89 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 20Last Post: 8th Mar 2007, 10:56 PM
