Results 1 to 6 of 6
Thread: Compound slide trouble..
8th Jul 2012, 08:29 AM #1Novice
- Jun 2012
- 32
- 12
G'day all, ive got myself a little problem and need a solution!
The underside of my compound slide (under compound slide to top face of cross slide) is rocking by .1 of a mm back and forth along the cross slide
Therefore when i take cuts the whole unit moves on me and interupts the cut.
I have cleaned it all and re-assembled it and fastened the circular slot nuts but i still have the same problem.
Is there a way to fix this? even if i have to remove the dovetail section and have it surface ground underneath.... Only problem is i have the cross slidelocation spigot in the way
Please share your thoughts
cheers Kon R
8th Jul 2012, 08:50 AM #2Most Valued Member
- Sep 2011
- Ballarat
- 3,103
HI Kon,
are you sure it isn't rocking under the tool post.
Just a thought.
Phil
8th Jul 2012, 09:11 AM #3Most Valued Member
- 4,890
What type of lathe is it?
8th Jul 2012, 10:41 AM #4Philomath in training
Is this the Keiyo Seiki lathe that you bought recently?
I think a picture or two to illustrate the problem might help. One thing - are your compound bolts clamping up tight? I ask because I had similar problem once where the bolts had been replaced but one was slightly too long and so while the nut was tight, the T bolt was not clamping properly.
8th Jul 2012, 03:32 PM #5Novice
- Jun 2012
- 32
- 12
phil
hey mate, its not rocking the toolpost. Ive had my dial on the lower section of the compound slide
cheers kon
8th Jul 2012, 03:36 PM #6Novice
- Jun 2012
- 32
- 12
michael g
Hey Michael G, yes its the keiyo seiki.
just checking everything on it and this is my only real problem so far.
I'll have to check out your theory though that may be it... problem is i have to wait til next week til i go back to my workshop
thanks kon
How does the small compound slide come apart?
By Com_VC in forum THE HERCUS AREAReplies: 5Last Post: 1st May 2011, 01:21 AM
