Results 1 to 15 of 18
Thread: Turning Tapers & Trigonometry
10th Jun 2012, 07:07 PM #1Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
This is further to the recent thread called "Stop for Second Chucking Operations"
Both "Localele", "Anorak Bob" & myself have been communicating on a suitable design for use in Hercus Lathes both the model 260 & the 9 inch model, for a workpiece stop behind the chuck.
The 260 model requires a No 4 Morse Taper adaptor or insert to go into the Headstock Spindle.
Whenever, I have gone to turn a precise taper in the lathe its always been a bit of trial & error, hit & miss, in getting the compound set up to the accurate angle.
A while back I noticed a bloke on "The Practical Machinist Forum" in the USA using a Sine Bar concept to set up. The idea looked good.
So I got to making up a fixture to take a small 3 inch long Sine Bar I had.
The photos explain it.
A No 4 Morse Taper has a 1 degree & 29 min & 15 second angle off the centreline.
The Sine of this angle (from tables) is .0259" times 3" (sine bar length) = .078"
So I set the Sine Bar with gauge blocks & feeler gauge to this height,
& ran it past a dial indicator until the compound slide angle was right.
Then confirmed this by setting up a no 4 Morse Taper in the lathe (see Photo)
& ran the dial indicator along it. There was hardly a flicker in the half thou needle
So now all is ready to start machining the taper.
I accept this is a bit of a longwinded way to do the job, but just wanted to try out this method .
More to follow.
regards
Bruce
10th Jun 2012, 07:19 PM #2future machinist
- Mar 2008
- nowra
- 1,598
Nice work threre that's a complex process
Andre
10th Jun 2012, 09:42 PM #3Member
- carrum
- 51
The sine bar method is a toolmakers technique, my uncle taught me that many years ago.
10th Jun 2012, 10:50 PM #4.
- 6,459
Should be natural for Bruce, he's a toolmaker.
I imagine you will be cutting the taper in a couple of passes Bruce. If you lived a bit closer you could have come around and picked up my TTA. But if you did live closer we would be drinking red plonk and would have forgotten about 4 Morse tapers.
Ha Ha
BT
10th Jun 2012, 10:59 PM #5Pink 10EE owner
- 6,218
Just remember the tool has to be spot on centre height, otherwise the taper will be wrong.
11th Jun 2012, 09:28 AM #6Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
On dead centre
RC
Yep, I will ensure the tool is on dead centre, I remembered that important point.
Bob
Its not very often I turn tapers & the Taper Turning Attach would be a nice thing to own.
Have you had a drop of that marvellous Margaret River red lately.
Its got great healing benefits !!!!
Probably a good thing we are seperated by the Nullabor, otherwise we would be doing a lot of talking & sampling
regards
Bruce
11th Jun 2012, 10:27 PM #7Golden Member
- Apr 2008
- NSW
- 537
Nice setup , it should yield accurate results as long as the base plate angle is in line with the lathe centre . I also use this principle to turn tapers . On my lathe it is easier to just bolt the sinebar attachment to the compound and line up on the tail-stock shaft or a test bar in the chuck or between centres . Works good for me and I can turn any short fractional taper upto about 40 degrees half angle. Tapers are much easier now with this sinebar tool but it took some time to work out how to calculate the tapers and stack heights . Now I have two small Dos programs that take the math right out of the whole equation , pardon the pun .
11th Jun 2012, 11:04 PM #8Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Bruce,
Would I be correct in saying that as you have the base attached to the dovetail, that the DTI should read zero along the sine bar? The topslide will be taking that path while machining so should be near enough to perfect.
Phil
12th Jun 2012, 04:20 PM #9Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Correct
Phil
Yes that is exactly what happens, the cast iron (Scraped of course) clamps into the dovetail of the compound slide ( also scraped), & the DTI is run along the top of the preset sine bar by moving the lathe carriage. The compound slide angle adjusted till the DTI reads zero.
Today I put it to the test.
I have never liked turning tapers, as from past experience its always been a bit of trial & error, with lots of error
Half an hour ago I turned the no 4 Morse taper, put on a smear of prussian blue & tried it in the headstock.
Yippee, right first go
So pretty happy with the new set up using the sine bar & DTI.
Apart from the 3C collet adaptor I am making, also doing one for "Localele" Micheal.
So things are progressing well.
regards
Bruce
ps A light finishing cut of a few thou will follow what you see in the photo
12th Jun 2012, 05:15 PM #10Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Excellent Bruce.
I have never had a use for sine bars before....until now.
Normally on my lathe I use the cone function of the DRO. Never absolutely accurate but normally good enough. Looks like sine bars go on my list of 'keep an eye out for'.
Phil
12th Jun 2012, 09:26 PM #11Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Sine Bars
12th Jun 2012, 09:30 PM #12future machinist
- Mar 2008
- nowra
- 1,598
On second inspection that set up does'nt look that complicated. Now to get some gauge blocks and I cam use my sine bar
Andre
12th Jun 2012, 10:47 PM #13Most Valued Member
- Sep 2011
- Ballarat
- 3,103
12th Jun 2012, 11:19 PM #14
Here is an idea - just to ponder:
using this set-up - and in the absence of gauge block ownership - could you fit a micrometer screw/spindle into the angle base for the sine bar, in the position where it will touch the deflected roller?
That would allow you to quickly and easily adjust the angle against an existing taper or a precision protractor.
I'm considering this thought because I happen to have a spare micrometer spindle and no gauge blocks..... I believe a sine bad could be home-made for this purpose - or am I way off?
Thoughts?
Joe
edit: hang on a sec, looks like other people have figured this out too:Last edited by jhovel; 12th Jun 2012 at 11:21 PM. Reason: found an image of what I was thinking....
12th Jun 2012, 11:43 PM #15Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Joe
What an excellent idea, to use a micrometer for the Sine Bar instead of gauge blocks.
I have just recently purchased a set of low price gauge blocks from the USA.
Before that Ive been using feeler gauges bunched together & or Starrett adjustable parallels.
The micometer would work well
regards
Bruce
ps
Ideas never stop on this forum.
turning tapers.
By wm460 in forum METALWORK GENERALReplies: 26Last Post: 15th Feb 2011, 11:09 PM
