Results 1 to 15 of 54
Thread: Junk yard finds and their uses
7th Jun 2012, 10:23 PM #1Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
I thought it would be fun to have a thread about the junque we drag home and then wonder what to do with. (Everyone does that, right? )
I don't mean repairing stuff for its original use, but creative 'repurposing'. (The word makes me cringe but it does convey the intent.)
Four eggs ample. Today I picked up this actuator from a hospital bed. I don't have the right sort of electrons to test it yet, so I don't know if it works or how far or how fast it moves. I suspect 'not very' in both cases. There are specs on the maker's website that I'm still trying to digest, but you can see it has a load rating of 6000N. Which sounds like a lot. But a duty cycle of 10%, which doesn't.
So assuming I can get it working, what the hell can I do with this treasure?
7th Jun 2012, 10:26 PM #2Old Fart (my step daughters named me)
- Sep 2010
- Mallala S.A.
- 76
- 50
You could use it to lift the tiolet seat.
7th Jun 2012, 10:26 PM #3Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Drive your topslide on the lathe
Phil
7th Jun 2012, 10:53 PM #4Senior Member
- Mar 2009
- Blue Mountains
- 195
I have a similar type of device, same function, different shape. I am considering making a lifting mechanism for a flat screen TV so the TV can be hidden down behind a cabinet and raised as required.
Mm.
7th Jun 2012, 11:06 PM #51915 17"x50" LeBlond heavy duty Lathe, 24" Queen city shaper, 1970's G Vernier FV.3.TO Universal Mill, 1958 Blohm HFS 6 surface grinder, 1942 Rivett 715 Lathe, 14"x40" Antrac Lathe, Startrite H225 Bandsaw, 1949 Hercus Camelback Drill press, 1947 Holbrook C10 Lathe.
7th Jun 2012, 11:30 PM #6
8th Jun 2012, 08:02 AM #7Philomath in training
Tips around here don't allow you to take things away and hard rubbish collections that the council run are generally filled with broken furniture and tree prunings. However, at the last place I worked word got around that I did stuff with machines at home, so it was getting to the stage where I would have people approach me and ask if I wanted an old ________ that they were about to toss out because they didn't want it but it still worked...
As for the actuator, think of it as a pneumatic cylinder replacement - anywhere you can use one of those, you can use this. Usually they have motor driving a worm in them. If you were only lifting a light load you would be able to use it more often than the duty cycle would suggest. Pity your ute is only 12V (or it's 24V), as you could use it to provide motion on that. (I've seen them on water trucks to lower a tree watering boom)
8th Jun 2012, 09:39 AM #8Golden Member
- Feb 2010
- Ballina, NSW
- 900
Mini press? might be OK for sheet metal. Or some sort of clamping device?
8th Jun 2012, 09:42 AM #9
You could convert your recliner rocker into one of those dawson chairs. Those ones that push you up and tip you out of your chair. May not need it today but you can start on it.
8th Jun 2012, 09:48 AM #10Member: Blue and white apron brigade
Auto door closer repurposed for a jointer guard.
Light cover for my welding bay fume hood made from a clothes dryer door.
Mobile Pizza oven made from clothes dryer drums. We even take it camping.
8th Jun 2012, 10:10 AM #11Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Putting it down might be more relevant. Never mind...
That sir is a noble idea. Do you mean remove the compound's screw and replace it with this doover? You would lose manual control. Or do you mean just use the motor and connect it by other means to the existing screw?
That sounds like it would need a fair bit of travel. I think this only has 100mm or so. But if it can lift 600kg (thanks Laird) I guess you can leverage the travel. So to speak (it's kind of the opposite of leverage). What's a telly weigh these days?
I feel lucky to have an old-school dump. I wonder how long it can last? Better stock up while I can.
A LINAK® electric linear actuator consists of a motor, a gear and a spindle including a nut.
Good plan, I might finish it by the time I need it.
Thanks for all the suggestions so far.
8th Jun 2012, 10:38 AM #12Most Valued Member
- Sep 2011
- Ballarat
- 3,103
8th Jun 2012, 06:21 PM #13Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
Linak actuator
Bryan, you've done well providing the actuator is not buggered. If it is, it can easily be repaired by Linak. I don't recommend pulling it apart, there's nothing servicable in there that you can fix.
I've used the LA31 actuator in many applications, and have had a close association with Linak here in Melbourne. The actuator is worth several hundred dollars and requires a control box and hand set to operate it.
The control box has built in over current sensing to stop the actuator at it's end stop positions. If hard pressed, I might be able to obtain a "shop soiled" control box etc.
I've used Linak actuators in beds, window shutters, hatches, TV lifts etc, and can vouch for their excellent quality and back up service.
Ken
8th Jun 2012, 10:09 PM #14Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Oops. I already pulled it apart.
Ken
I didn't find anything too scary in there. The only snag is those two big springs are very difficult to reinstall. In fact I haven't managed it yet.
Looks like it has potential as compound feed.
I bodged a power supply out of an old transformer and a $2 bridge rectifier. A switch to swap polarity and it was winding in and out like a champ. Later I googled rectifiers and found out how complicated they are. Sure glad I didn't do that first! It would be great to know if there's any real need for those sophisticated control systems. Hope I'm not doing any damage with my crude setup. So Ken I don't know if I need to press you hard or not.
It runs too fast for a power feed as is, so I guess I would ultimately be using a PWM module if that's the application. But there is another possibility. I also have a use for a gate opener - at least I would like to - and I think this would be perfect.
8th Jun 2012, 10:32 PM #15Philomath in training
I'm guessing that those two stiff springs are there to provide an increase in torque that the current sensor can detect. (that is, at the end of stroke you compress the spring as well as push the load and the sensor has time to react to the increased current draw).
Last time I had a spring moment like that I (very carefully) compressed it in a vice, held it closed with some wire and then once in position un-twitched the wire. Safety glasses, a restraining device through the spring while compressing etc.
If I read the model number correctly it has a 150mm stroke. You might be able to slow it down by running on 12V. The electronics may not let you, and you won't get the full 6000N, but may do what you want.
