Results 16 to 30 of 54
Thread: Junk yard finds and their uses
8th Jun 2012, 10:32 PM #16
That is a great idea Bryan. I too suffer from this sickness of repurposing stuff others are throwing away. For example I built my entire Lathe workbench from timber that was being thrown away at work.
Attachment 211537
The store I work at is going through a complete remodel. I have acquired several flourescent lights, wood, and a 1/3 hp motor that was hooked to a CO2 compressor for a soda machine. I thought maybe I could replace the motor on my drill press with it.
Bret
9th Jun 2012, 01:42 AM #17Most Valued Member
Hi Bryan,
Is that old transformer 24VAC? You'll be getting something like 30V.
9th Jun 2012, 02:15 AM #184-6-4
- Mar 2009
- 260
Junk yard
Greetings Chaps I don,t have the inclination to hang out at junk yards but I do keep an eye out for stuff left on the nature strips. I once asked a passerby to help me load a wardrobe. But the subject here was an old set of shelves I have included a couple of pics previously seen on this forum but there are always new bodies. It had been turned into a multi leaved storage cabinet for my hand tools. The problem is putting the tools back in the cabinet. I also had the habit of scrounging steel from my old place of employ. The offcuts rack was a joy to behold. Yours 4-6-4
9th Jun 2012, 10:12 AM #19Golden Member
- Nov 2005
- adelaide
- 597
i better add this i found at a garage sale for $5 he didnt know what it was
a head off something with 1 1/2 x 8tpi thread on one end
internal number 3 mt
other end has some sort of internal taper but not anything i have that fits
vertical and horizontal swivel with graduations
centre height approx 3 1/2 inches
9th Jun 2012, 10:28 AM #20Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Michael, what you say could be correct. But there is also a pair of limit switches - the blue thing. The grey sleeve moves slightly at each end of the stroke and that trips the switch. The springs re-centre the sleeve when the pressure is released. Even using hand pressure to simulate the springs it seems to work very well. So I'm not sure if current sensing is needed.
Your advice on the springs sounds... sound. I will only go to the trouble if I decide to use it in linear mode. And you're correct on the stroke, well spotted. I measured about 144mm, taking approx 27 seconds.
You might be able to slow it down by running on 12V. The electronics may not let you, and you won't get the full 6000N, but may do what you want.
Stuart, yes 24 VAC. But I think I was getting 22.x from the bridge. Did I do it wrong? Tranny output is true to label.
9th Jun 2012, 11:01 AM #21Most Valued Member
Rapidly heading out of my depth Bryan(not that deep though lol)
22VAC will likely(?) be RMS volts. The peak Voltage will be 22 x (the square root of 2 or 1.414)=31.10
The bridge will cost you about 1.2V so 30V
Also I'm told that DC motors dont particularly like running on full wave rectified AC.
You dont have a half dead 18V cordless drill in the junk pile?
Now if someone would turn up that really knew what they were talking about
9th Jun 2012, 12:02 PM #22Most Valued Member
- Australia east coast
- 2,713
9th Jun 2012, 12:06 PM #23Most Valued Member
9th Jun 2012, 12:09 PM #24Senior Member
- Apr 2010
- Rural Victoria
- 358
Repurposing? Is that what it is called? Help, I suffer also. LOL!!
Is there a twelve step program?
Here is a nicely powdercoated Schneider cabinet, thrown out because it was the wrong colour
I purchased a Kincrome tool set some years ago and made a point of reffitting this cabinet rather than buying the purpose built Kincrome one. Took me days, but then I would not have successfully repurposed this sexy cabinet.
Current repurposing activity includes converting this natural gas Aquamax to electric. If it wasn't a stainless steel tank I wouldn't bother. I still have room for one of those cast iron gas rings they sell at Aussie Disposals at the bottom so I can also heat it up off a barby gas bottle as well. The new place has a shed that needs hot water for the occasional washing home brew bottles etc and doesn't have town gas. It's only a 2400w element so I can run it off a 15 amp socket.
Why? I suppose, like many of us, believe that too much good stuff goes to waste without even attempting to put a in little bit of effort to fix it or give it a new life. However I think I have burnt out my roundtoit with these projects
9th Jun 2012, 02:36 PM #25I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,295
9th Jun 2012, 02:55 PM #26
9th Jun 2012, 03:01 PM #27
9th Jun 2012, 03:02 PM #28
9th Jun 2012, 08:58 PM #29Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
9th Jun 2012, 09:41 PM #30
Have worked with Linak systems in patient lifters, hospital style beds etc. The dedicated controllers have a battery pack (2 x 12V bats for 24V DC), a mains powered charger module, controllers for individual functions (frequently more than 1 function on a unit) and a handpiece controller with two momentry switches per function.
Motor control is normally from the 24 V battery pack via a MOSFET to handle switching and a relay to handle reversing, but I seen some units that have a MOSFET for current limiting, and seperate relays for forward and reverse. Most of the units I have come accross used only a 2 pole 6.25 mm phone plug. so there was no provision for the limit switches to connect back to the controller. Hence they must be wired in series with the motor within the module.
With regard to operating from full wave rectified AC of roughly appropriate voltage, this is similar to early model train controllers etc. The motor is being fed a mixture of DC voltage, probably about 18V for a 24V winding, plus an AC ripple voltage of about 14V peak to peak comprising harmonics of the mains frequency up to 1000Hz or so. The DC component will drive the motor, but the current from the ripple component will flow through the motor windings generating heat but no usefull output power. As the motor is more heavily loaded, the DC component reduces and the ripple component increases. This is where it becomes difficult to run the motor off rectified AC, as the motor is loaded up, the ripple power disipation increases to the point where it can cook the motor.
The limited unloaded run that you gave the motor should not have damaged it.
Rectified power is used in many things, in conjunction with a filter stage involving large capacitors individually, or in sets connected by inductors. This increases the DC output voltage while reducing the ripple component significantly. For more critical situations, a regulator curcuit normally follows the filter stage to precisely control the DC output voltage and further reduce the ripple component.
