Results 1 to 15 of 21
21st May 2012, 01:49 AM #1Dave J Guest
Horizontal mill, what make is this one???
Hi,
I picked up this old horizontal mill when I bought the Alba shaper a while back. I just found a picture on the computer so I thought someone might know what make it is.
It is an old line shaft model and has a MT3 taper, table is around 800 x 230mm and the machine stands about 1400mm and 1000mm deep to give you an estimate of the size. When I got it it had a electric motor mounted on a swivel plate bolted to the side of the column. So someone has converted it over at the expense of grinding away some of the casting to get the belt to fit through.
It's an imperial machine (even though I gave metric above, LOL) and the only thing on it is a Demco badge, but they sold everything.
Also as can be seen it has power table feed and the coolant pump also run off the spindle. The power feed has a 4 speed gear box as well as a range of pulley sizes on the back that feed it.
The spindle bearings are the plain type, and the outboard support has a taper bush where you tighten it up take up any wear in it ( I wish they had of done on the HM52)
Dave
21st May 2012, 04:09 AM #2
What a cracker you have there Dave..WELL DONE.!!!!!!!!!!
I would be lost without my big horizontal mill.
Mate your shed is half the size of mine, And mine is FU*&%#@ full.
How in the lords name are you squeezing all this gear in?
Congrats on your new toy.
MattWarning Disclaimer
21st May 2012, 04:12 AM #3Senior Member
- Salem Ohio
- 219
I don't know but it looks like a keeper. Maybe have a look around Tony's site and if your isn't listed and you do find out what it is send him some pics...Bob
lathes
21st May 2012, 08:39 AM #4.
- 6,459
Is the ruler hiding battle scars Dave? If not then that table appears to be in good nick. Nice looking little mill.
BT
21st May 2012, 02:17 PM #5Dave J Guest
21st May 2012, 02:20 PM #6Dave J Guest
21st May 2012, 04:00 PM #7Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Manufacturer of Mill
Dave
Could be a Denbigh.
Not sure if the spelling is correct, but it looks like that type of Mill.
regards
Bruce
21st May 2012, 07:22 PM #8Dave J Guest
Thanks Bruce,
They made them strong back then, cast iron coolant tank, LOL
I also like the telescopic knee screw and I am pretty sure it headed for the HM52 once I put the riser on. On the HM52 I would either run out of screw with a riser, so it's either raise the mill up to clear a longer one, or drill a hole in the concrete like some of the older horizontal mill, neither of them is happening so this screw will fit the bill just nicely.
Dave
21st May 2012, 07:54 PM #9Most Valued Member
- 70
- 1,513
Looks like the one near bottom of this page. Actually come across it searching Google pics for Denbigh.
Page Title
Nev
21st May 2012, 08:05 PM #10Dave J Guest
Hi Nev,
You have hit the nail on the head thee, thanks.
A few small differences, but it looks like it's a Pallas mill (at the bottom of the page)and it states it is not British made but foreign made, which I know Demco where importers of foreign made machines.
Dave
21st May 2012, 08:46 PM #11Most Valued Member
- 70
- 1,513
I kinda like the Pallas H00 mill here.
Model Steam Engineers - Pallas milling machine
Bit like a Hercus.
Nev
21st May 2012, 08:47 PM #12Dave J Guest
Hi Bob,
I checked it and no big scars, just a few very small ones that looks like something has been dropped here and there, but not in that spot where the ruler was. I think I placed it there for scale for the size of the machine.
You can see a patch on the front where I gave it a rub with a scourer to see what it was going to come up like and it also has a bit of green paint on it.
Dave
21st May 2012, 08:50 PM #13Dave J Guest
21st May 2012, 09:01 PM #14Dave J Guest
Here are a few more pictures which confirms it is just like the one in the link from Nev.
This is where they ground out the casting for more clearance of the motor belt.
The helical back gears
Another shot of the butchered casting
The tapered bronze bush for the horizontal support, which can be adjusted to take out wear along the way.
You tighten the out board nut on it, which pulls the bushing into the taper more and closes the bushing down on the arbour sleeve.
Dave
22nd May 2012, 09:29 AM #15Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Vertical Milling Head for Horizontal Mill
By seafurymike in forum METALWORK GENERALReplies: 42Last Post: 16th May 2012, 05:23 PM -
Assessing old horizontal mill
By Bryan in forum METALWORK GENERALReplies: 15Last Post: 6th Dec 2010, 04:29 PM -
Overarm jammed on horizontal mill
By 19brendan81 in forum METALWORK GENERALReplies: 19Last Post: 1st Sep 2010, 01:09 PM -
Vertical lift screws binding in old horizontal mill
By 19brendan81 in forum METALWORK GENERALReplies: 19Last Post: 26th Aug 2010, 12:15 PM
Members who have read this thread: 0
There are no members to list at the moment.
