Results 1 to 5 of 5
Thread: Waldown ..... again
13th May 2012, 10:05 PM #1.
- 6,459
Waldown ..... again
The base model drill has a fanciful depth indicator dial. It's fanciful because it doesn't work but it does look good. The red anodised dial appears to be adhesve fixed to its steel backing plate. The plate is loose on the pinion shaft and the return spring moves axially on the shaft. Feels like something is missing.
Does anyone own one of these drills and if so is there any chance of enlightenment?
I can make something up to positively fix the dial to the shaft but it would be nice to keep things original.
Also does anyone know the belt lengths for the 8SN or the Workmax WITH the intermediate pulley? Going by my 3M, they are not the same as the 2 or 3M.
BT
13th May 2012, 10:35 PM #2Philomath in training
- 6,563
This is off my xM (I can't work out whether it is a 2 or a 3 - the name plate says 2 but it has a 3MT)
Attachment 208305
It's a friction driven thing, so it can be adjusted by hand but rotates with the feedshaft. As yours has an inscribed mark on the casting, I suspect that the anodised label is a non standard addition. As it is you couldn't read it properly while using the drill.
On edit - let me know if you would like me to pop it off and photograph anything insideLast edited by Michael G; 13th May 2012 at 10:36 PM. Reason: Added
13th May 2012, 11:29 PM #3.
- 6,459
13th May 2012, 11:36 PM #4
Bob,
maybe it just had a wavy washer behind the circlip?
14th May 2012, 11:32 AM #5
Another Waldown - this time a tart up.
By Anorak Bob in forum METALWORK GENERALReplies: 66Last Post: 26th Jan 2013, 01:28 PM -
Another Waldown
By Anorak Bob in forum METALWORK GENERALReplies: 5Last Post: 17th Sep 2011, 12:06 AM -
Waldown Drill Press
By KevM in forum METALWORK GENERALReplies: 24Last Post: 1st Sep 2011, 01:31 AM
