Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Milling machine
  1. #16
    Jun 2011
    Australia east coast
    2,713
    Quote Originally Posted by lamestllama View Post
    Hi all,
    Yesterday I became the proud owner of a milling machine and some accessories photos are attached.
    I only got one picture of the mill. It is supposed to be a Taiwanese machine from 1978. Can anybody identify the machine?
    You will notice amongst the accessories is a Myford indexing attachment with two plates.
    Unfortunately the previous owner has had some sort of mishap and machined the centre T- Slot wider for quite a large portion of its length. I will try and get some more photos of this, hopefully some of you will have ideas on how this could be fixed.
    Also the machine is 3 phase, I should have got a picture of the motor plate too. I am going to need a VFD anybody have any suggestions on a brand and supplier ?
    Eric
    Those are good little mills, I picked one up for a friend of mine some years back. He's been very happy with it. I have a small horizontal mill with the same size table, a very useful machine.
    His was also 3 phase and the motors were easy to jumper over to 240V - 2 motors as he had power feed also. He used 2 of the single phase 240V-3 phase 240V VFD units.
    As long as the T slot can hold well, I'd forget about it. You cannot restore it to original condition no matter what you do, so go with function.
    PDW
  2. #17
    Jul 2011
    Adelaide
    837
    PDW,
    It is great to know that the motors are easy to wire for 240V VFDs
    I think possibly you are right and I may have to go for function. But maybe someone on this forum might come up with a brilliant fix which is trivially implemented.
    Eric
  3. #18
    Feb 2007
    Katherine ,Northern Territory
    69
    736
    Michael,
    I agree with your thoughts on how the slots originally got messed up. I also agree that the lip even on an undamaged section did not look wide enough. Like you I am not sure how to rectify the issue with minimal risk.
    BTW I think the T-slots may have been taken out to 3/4" attached is a photo that I scaled that dimension of using the fact that the table is supposed to be 205mm wide.
    Eric
    The tee slots on my machine are 14mm .
    I have a parts manual from a similar mill , shows a (not very good ) schematic of the parts , but it gives some idea .
    I have attached it ,and a Grizzly manual also , similar machine.
    My machine has no markings at all , but you can see where one was fitted at one time.
    "Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
    Groucho Marx
  4. #19
    Aug 2009
    Keysborough, Melbourne
    86
    75
    Default Edit Again
    I have a mill which looks the same but has McMillan branded on it. Actually it is my sons but he uses my shed and I use his machines.
    Will try to find out more and post a pic.
    Robbo37
    Couldn't upload photos but they are here, (I hope)
    https://picasaweb.google.com/1142268...4/ShedMachines
    R37
  5. #20
    Sep 2006
    Mallacoota,VIC,Australia
    53
    1,010
    HI,
    Guys I've just realised I have made a BOO BOO. Where I had said that I had seen one of these Mills Branded Mcpherson it is Wrong. What I should have said it that I have seen one of these Mills Branded 'Mcmillan'. The Posting by robbo37 has made Me realise My mistake -Sorry Guys.
    One another Note could the Guys that have these Mills Please tell Me what sizes their Belts are Motor & Spindle ?. The Herless SM-1 that My Boss has, has got the wrong length Belts on it cause we can't Change Speeds properly.
    Thanks Guys.
    All The Best steran50 Stewart
  6. #21
    Sep 2006
    Australind , WA
    58
    1,281
    Quote Originally Posted by steran50 View Post
    HI,
    Say three "Hail Mary"s.....
  7. #22
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by Woodlee View Post
    Your mill is identical to mine ,except mine is single phase.
    I have no manufacturers plate on mine , but I believe these machines were sold by H&F .
    Mine needs a head rebuild , the bearings are a bit noisy ,but it's a job that will get done one day. I fitted a power feed to mine for x y feed.
    edit
    Just noticed in this pic it has the Myford dividing attachment set up on the table . I use the Myford lathe milling slide to mount the attachment to the table .
    Kev.
    Kev,
    I just noticed your stand. I like the fact you can move your machine around while still having the ability to lock it in place.
    I visited my mill again today, It made me realise how short it is, so I definitely need something to raise it to a reasonable height and a stand like yours would be just the ticket.
    Thanks for providing the inspiration
    Eric
  8. #23
    Jul 2011
    Adelaide
    837
    I am resurrecting this thread because I have finally put a VFD on this mill and surveyed the T slots. I have come to the conclusion they where originally milled out of parallel with the ways by about 2mm over the length of the table. The previous owner then milled a ~450mm portion of the top part of centre slot parallel with the ways and leaving very little lip to grip with a T nut in to sections.
    Ideally I would like the T slots somewhat parallel with the ways all the same size and functional. In theory this should mean taking no more than 1mm deep cuts from any part of the T slots and then some custom nuts.
    Also in theory it might also be possible to do this on the machine by swiveling the head around to reach all of the table. In practice I have gratefully accepted an offer by Michael G to fix them.
    Eric
  9. #24
    Jul 2011
    Adelaide
    837
    edit
    Kev.
    Kev,
    It has been a while but I noticed that you said you fitted power feed to your X & Y axis. Can you provide any details on how?
    Eric
  10. #25
    May 2011
    Murray Bridge S Aust.
    5,959
    Woodlee was last on 6 Feb at around 2PM. You could try sending him a PM?
  11. #26
    Jul 2011
    Adelaide
    837
    Default The conclusion.
    After 7 years of sitting around being a boat anchor I finally have a milling machine. I give most of the credit to Michael G who made me a set of leads crew nuts that has resulted in 0.15mm backlash (down from the 1.4mm backlash I had in both screws) and for a fantastic fix of the major stumbling block which was fixing the T-slots on this machine.
    The problem with the T slots turned out to be that in manufacture they ran out by 2mm in the Y axis in the length of the table. Left alone this would have been useable except the previous owner had decided to straighten up the middle portion of the centre slot but only did so with the top of the slot and not the bottom of the slot meaning that there was only a 2mm or so ledge for any T nut to grip on at parts of the T-slot.
    Pictures showing the effect of this are IMG_20190506_182627.jpg and more closely here IMG_20190418_114200.jpgand hereIMG_20190418_150507.jpg
    And after Michael straightened out the slots IMG_20190610_164350.jpg.
    And as proof it is no longer a boat anchor here making its first part for my use (I machined a flat on a cast iron part for my father first) IMG_20190620_142322.jpg and the part actually worked out its the clevis on the end of the cylinder rod IMG_20190620_170504-1.jpg.
    So after a lengthy gestation thanks mainly to Michael G I have an operational milling machine.
  12. #27
    Apr 2015
    Tungkillo, South Australia
    87
    74
    Excellent. You will find many uses for the Mill. If your finances have recovered, get a DRO for it. You will never have to worry about backlash again.
  13. #28
    Jul 2011
    Adelaide
    837
    Quote Originally Posted by cfranks View Post
    Thats very high on my wish list. What finances?
  1. Used Milling Machine
    By woodfast in forum METALWORK GENERAL
    Last Post: 15th Apr 2012, 10:07 PM
  2. Milling machine
    By paulj in forum METALWORK GENERAL
    Last Post: 8th Oct 2011, 10:14 PM
  3. A little help with my first milling machine
    By festy_ in forum METALWORK GENERAL
    Last Post: 13th Apr 2011, 11:34 PM
  4. Milling Machine
    By R W in forum METALWORK GENERAL
    Last Post: 17th Mar 2011, 09:02 PM
