Results 1 to 8 of 8
Thread: Hendey wiring
    Jul 2008
    near Warragul, Victoria
    3,726
    Default Hendey wiring
    Out of interest , a few pics of the Hendey wiring setup.
    A friend of mine who is an eletronics guru, has suggested the motor is of the type that changes from Delta to Star or vise versa as it is running .
    There are two devices in a box under the bed , one of which appears to be a change over relay , and down the end , on the leg , is what i think is an overload trip .
    I'm pretty sure the motor is original and 72 years OLD ! I am dubious about the insulation inside it
    Jan 2007
    Katoomba NSW
    209
    1st pic is the Star/ Delta contactors, 2nd is the run contactor and thermal overload and the 3rd pic is an isolator (on/off switch). Get an electrician to megga the wiring and motor before powering up. That will test the insulation of the motor windings and the control wiring.
    Built: a Bench,a Desk,an Archery Display,
    Those were the droids I was looking for.
    Jul 2008
    3,726
    Default more
    OK
    In the first pic above (HENDEY1) , both devices are relays
    behind the relay on the left is this , it is a manual switch ... four copper strips , go into ceramic contatcs ..does this lock it in either mode ..delta eg
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi Mike,
    I think you might have to consider rewiring the machine, I wouldn't be tempted to power it up without megger testing.
    Old insulation can become crumbly and short out, can be dangerous.
    What details do you have on the motor?
    I can't remember if you have 3 phase power or not?
    Star delta starters are readily available if you wanted.
    Jan 2007
    Katoomba NSW
    209
    Not sure what it switches but it may isolate the control supply. Is that a transformer above it with a small glass fuse on top or is that just a catch?
    You wouldn't lock it in Star or Delta. It starts in star to reduce starting current then switches to Delta after a preset time period usually a couple of seconds. Long enough for it to run up to speed.
    A contactor is just a higher current rated relay with three or four poles to switch all three phases at once.
    Jun 2008
    Victoria, Australia
    74
    5,080
    Hi NCarcher,
    Yes, looks like a transformer for the control voltage, I can't see any coil voltage ratings on the contactors, could also possibly be for a work light?
    Jul 2008
    3,726
    Default Ok
    I posted the pics out of interest .
    My plan is to strip the whole thing and rewire it .
    The motor in it is 3 HP .... I will buy a new ( or good used ) 3HP 240 / 415 3 phase motor and run the VFD .
    I don't like the thought of the 72 year old wiring inside that motor
    I spotted a megger at the hamfest ....
    MIKE
    Jan 2007
    Katoomba NSW
    209
    Hi NCarcher,
    Or a coolant pump?
    MIKE
    Handy items to have. Grab one if it's cheap enough. I have an awesome bakelite wind up one. In new condition. I couldn't resist it.
  1. HENDEY is here
    Last Post: 17th Mar 2012, 08:30 PM
  2. Hendey 12 X 30 lathe
    Last Post: 29th Feb 2012, 12:51 PM
