Results 1 to 14 of 14
Thread: Lifting Lathe
30th Mar 2012, 02:40 PM #1
Lifting Lathe
Hi Guys. would it be OK to put a large bar in the chuck to lift the lathe or would it load the bearings and the spindle too much. It is a h&f lathe.
Kim
30th Mar 2012, 02:58 PM #2Banned
- Jul 2011
- Melbourne Australia
- 1,376
Probably best not to if you can avoid it. Especially with a bar as it extends further out from the bearings. Those that do elect to lift by the spindle, normally choke a soft sling, behind the chuck.
What model is it, would I find a picture of it on H & F’s site.
Phil.
30th Mar 2012, 03:00 PM #3Most Valued Member
- 4,890
Are you planning on lifting on both sides of the headstock.
This would be better and safer than just lifting from one side.
You may need to wind the carriage and tailstock towards the headstock to try and get an even lift if dont use a sling around the tailstock end of the lathe.
You could probably get away with a piece of pipe rather than solid bar.
30th Mar 2012, 03:05 PM #4
Hi Phill
It is an al335.and weighs about 350kg
Kim
30th Mar 2012, 03:11 PM #5Pink 10EE owner
- 6,218
With my AL1000 I just used a soft sling through the bed stiffeners. Lifted it from the one point... It did balance fairly well..
30th Mar 2012, 03:12 PM #6Banned
- Jul 2011
- 1,376
Is it on the stand like this one?
http://www.machines4u.com.au/view/gallery/?advert_id=7005
If you open those doors up, is there provision for lifting bars under there?
Phil.
30th Mar 2012, 06:17 PM #7
Hi Guys
I didnt see any provision for lifting bars but I will have another look.
Thanks guys.
Kim
30th Mar 2012, 07:55 PM #8Golden Member
- Apr 2008
- NSW
- 537
Dont lift the lathe by the chuck or spindle . Take the chuck off and use slings . Cut some stout steel bars and place them under the bed with the slings down inside the bed holes.
Then use elastic octocords to strap the bars in position so they do not move or fall away when no lifting strain is on the slings. You can slip some thin rubber mat between the bar and the lathe bed if you like. Adjust the sling position near the tailstock so a balance can be struck , some lathes will balance with both bars near the headstock because that is the heavy part. Move the tailstock about to aid balance . Only lift it a few inches to check the balance and once found then only lift the minimum height to achieve the move . Dont wrap slings around the outside of the lathe bed as the lifting pressure can and will bend the lead screw or feed shaft.
I saw a photo on a H&F catalogue of a fairly large lathe being delivered being swung by just a single sling on the chuck . Made my blood run cold. We know it is a strong part of the lathe but why put that much pressure on precision bearings , funny how after I mentioned it the photo was gone next catalogue . I don't care how many experts say it is ok , it is not ok.
Don't be tempted to do a half ass job of lifting a lathe as many people drop them and wreck them forever.
If you don't have good slings go to Repco or Super Cheap Auto and buy a non stretch towing sling and just double it up a few times to form a Y sling . They also sell good quality 2 ton rated recovery bow shakles .The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
30th Mar 2012, 10:40 PM #9I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,295
This photo is taken from my AL335 owners manual, and is how I lifted mine. Seems to be pretty well balanced when lifted in this fashion. Obviously you need to make sure you thread the sling behind the control rods to avoid bending them!
30th Mar 2012, 11:39 PM #10Diamond Member
- Sep 2006
- Australind , WA
- 58
- 1,281
I made a bracket that used the bed cap screws to attach it to the lathe and lifted mine with that. A lot easier and less scary (IMO) than using slings under the bed. No chance of it tipping or slings slipping. ( I don't know if they CAN slip but that was a fear.)
sterob
31st Mar 2012, 08:49 AM #11Most Valued Member
Hi all,
When I lift mine, I go by the user manual which also recommends a sling around the bed. With the tailstock removed and adjust the saddle along the bed to achieve balance. Also a second piece of tape rope can be attached to the end of the bed and back to the sling to give some more stability. I found this to be a very safe and secure method.
There are obviously people here with more expertise than me but lifting the lathe via the spindle and headstock seems to me to put a lot of stress on the spindle (bearings will handle it) and headstock bolts. Not suggesting the bolts will shear, far from it but why put stress on the bolts that hold the headstock in in precise location that you otherwise wouldn't want moving or adjusting?
31st Mar 2012, 08:56 AM #12Most Valued Member
31st Mar 2012, 09:30 AM #13Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Proper lifting slings are so cheap I don't know why you'd bother with towing straps: eBay: lifting sling
31st Mar 2012, 03:27 PM #14Golden Member
- Apr 2008
- NSW
- 537
It is not a matter of price so much as availability. Many people have a Repco or Supper cheap auto handy but no industrial lifting supply . I could not buy professional lifting slings for anywhere near as cheap as the heavy duty tow strap was at the time and back then there was nothiong much on e-bay like there is now. I agree that the slings on e-bay are good value and worth getting if you are not in a hurry.
Also the strap will also be useful for towing a vehicle when the lifting is over .
It also lifted a milling machine that was heavier than my lathe by just wrapping it multiple times around the head travel castings .
Another useful bit gear is the cheap Chinese electric winch . I dragged my milling machine into place on steel roller bars by placing a t- bolt anchor in the concrete floor and connecting a chain to that .The volume of a pizza of thickness 'a' and radius 'z' is given by pi z z a.
safe lifting points of hafco 960b lathe
By lather in forum METALWORK GENERALReplies: 35Last Post: 16th Aug 2010, 01:29 AM -
Lifting a Lathe
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 29th Apr 2010, 11:22 PM
