Results 16 to 24 of 24
26th Mar 2012, 09:22 PM #16Philomath in training
- 6,560
Attached is a graph whipped up at work (quiet day, niggling question - you know the one). Equations are from Glieck (8E)
It's for a piece of steel pipe/bar 100mm in diameter, 2 metres long suspended as a cantilever. There is a point load on the end - around 15kg from memory and the rest is self weight. The ID is as a percentage of the OD - really it could just be mm as it is 100mm OD
Attachment 202821
The key point to note is that as the bar is hollowed out the deflection due to the point load goes up slowly until the wall thickness becomes so thin that the pipe can not support itself as well and then shoots up. The deflection due to the distributed load is a gentle decline. Adding together gets a minimum roughly around an ID of 60 to 75mm. Note that this will change depending on the size of the point load.
So, Grahame's engineer was correct - sort of. A pipe with an ID of 3/4 of the OD deflects less if used as a cantilever because of the effect of self weight. If the bar/ pipe was used in a vertical position then only the point load curve applies, in which case solid is better. Stuart's comment is important, because he is essentially asking is less deflection the same as more rigid? It's only words but rigidity implies a stiffness and the value of Young's Modulus (which is a property that typically represents stiffness) remains the same.
It works this way because the middle bit of the bar/ pipe is carries only a small proportion of the load and it is a balancing job between the extra mass that middle bit contributes and the amount of the load that that part carries. The outside/ inside/ inside/ outside bit is a little confusing - I think that might be part of the explanation at the time that has not been completely remembered. I remember funny looking diagrams that I was shown once with inside & outside diameters but there was a whole lot of theory behind it that got a bit baffling...
(Boy can I waffle after a drink or two...)Last edited by Michael G; 26th Mar 2012 at 09:36 PM. Reason: Got it backwards; 2nd edit I think I've sorted myself out now...
26th Mar 2012, 09:38 PM #17
You "Boffs"
I asked a simple question and has led to this graph.
I will investigate the heavy walled pipe. But I am guessing that the concrete will be more affordable but thank you all for the interest my question has generatedJust do it!
Kind regards Rod
26th Mar 2012, 09:59 PM #18Most Valued Member
Hi Micheal,
Thanks, thats ###### brillant!
Hi chambezio,
Unless you take measures to be sure the concrete doesnt shrink as is curers I doubt its going to do much good.
26th Mar 2012, 10:25 PM #19
I don't think concrete is going to do much apart from promoting internal corrosion. It will definitely shrink and not contribute to the stiffness and if it did it would eventually crumble from vibrations. All that is an educated guess.
If you want to increase the stiffness significantly at low cost, find or shape a pieve of flat steel - somewhere between 3/8" and say 3/4" thick - and fitting as tightly as you can manage it to fit in the bore of the column. Position it in the direction of the bending force (i.e. fore-aft) and hammer/press/push it in, then tack weld at both ends to ensure it stays facing that way.
I think that will make a much bigger difference than concrete, epoxy granite or anything short of expensive very-thick-wall tubing or solid round.
Joe
27th Mar 2012, 09:50 AM #20Most Valued Member
- Australia east coast
- 2,713
27th Mar 2012, 11:02 AM #21
On The Merry-go-round
Well I have listened to all you learned men and have made some phone calls both near and far (hence the merry-go-round.) I need 70mmdiameter X 1200 long.
I have asked for heavy walled tube or solid. I have been told that 70mm tube is not a standard so I am now waiting for a couple of mobs to get back to me.
I have had "Oh, we don't carry that! You could try..." Gee I hate chasing stuff. I found on the net a crowd in Newcastle who make "precision" pipe and solids, so maybe they might come good.
On the off chance....does someone know of a source for the post?Just do it!
Kind regards Rod
27th Mar 2012, 05:13 PM #22
One quote I got today
71OD X 36ID carbon steel $195
70 OD 4140 $230
Plus freight of course.Just do it!
Kind regards Rod
27th Mar 2012, 07:56 PM #23Most Valued Member
Well now thats sorted, are you sure its the column thats the problem?
Have you thought about adding a backstay instead?
28th Mar 2012, 12:20 PM #24Most Valued Member
- 2,713
drilling machine made by Tough of Belmont, Perth
By greys in forum METALWORK GENERALReplies: 21Last Post: 18th Jan 2012, 01:47 AM
