Results 841 to 855 of 941
Thread: What did you learn today?
21st Jan 2021, 10:14 PM #841Member: Blue and white apron brigade
24th Jan 2021, 12:45 AM #842
To avoid porosity and weld cracks!
l have learnt today that cleaning up weld bevel before welding was very importand to avoid porosity inside the weld and maybe sometime weld cracks!
Last edited by Grahame Collins; 24th Jan 2021 at 06:07 AM. Reason: Link removed ,not relevant or necessary
24th Jan 2021, 09:37 AM #843
Flux can get damp through humidity /wet weather and also can give rise to porosity. Also re using flux that has not been cleaned will do it as well.
If you can locate a copy of the Lincoln Welding Procedure Handbook from Lincoln Electric,the book is pure gold in references to assist in settting sub arc and curing problems.
They are available only through Lincoln Electric as far as I know.
24th Jan 2021, 11:22 PM #844
Hi sembul,
I'll move your post to WELDING. This thread is not the most suitable place for it.
look for your original post
Looking for SAW wire S2Mo an Ti support
7th Feb 2021, 11:01 AM #845
I hate tapping threads more so just as you are qbout through the tap snaps with just a tiny bit either side to try extracate the thing.
30th May 2021, 08:11 PM #846Most Valued Member
- 70
- 1,514
I learnt that you can get Triple Square/Polydrive internal bit sets. Never come across them before. Not the same as Torx.
Nev.
30th May 2021, 09:31 PM #847Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,555
I learnt that my Mrs should not be left unsupervised to light the fire beads for the spit roaster...
2nd Jun 2021, 02:19 PM #848Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 226
3rd Jun 2021, 03:04 PM #849
3rd Jun 2021, 07:28 PM #850Gear expert in training
- 34
- 1,080
Yep, spiral taps for blind holes and gun taps for thru holes.
Cheap ones here https://mcjing.com.au/machine-tap.html https://mcjing.com.au/gun-tap.html
Suttons on special here https://generaltools.com.au/product-...-spiral-flute/ https://generaltools.com.au/product-...taps-gun-taps/Gear cutting specialists and general engineers www.hardmanbros.com.au
5th Jun 2021, 11:33 PM #851
or for really low cost (been using theirs for years now):
Banggood - https://www.banggood.com/Drillpro-M3...p-1458605.html
and
https://www.banggood.com/Right-Hand-...-p-944071.htmlCheers, Joe
9th Jun 2021, 02:10 PM #852Golden Member
- Apr 2019
- 596
Milling Inserts
Inserts for face mills are not necessarily available from multiple suppliers as they are often not ISO standard. Need to go to the original face mill maker....grrr. Yeah yeah you all knew that but I'm trying to catch up....
9th Jun 2021, 02:46 PM #853Gear expert in training
- 34
- 1,080
9th Jun 2021, 03:35 PM #854I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
I've got a 45 degree high rake facemill from H&F, which in theory takes SEKT inserts. Problem is the Chinese 'Mitsubishi' inserts I have don't carry the relief angle all the way to the cutting edge, there's kind of a chamfer for the last 0.5mm or so. Due to the amount of rake the inserts are presented with, this chamfer hits the workpiece before the cutting edge. I had to touch up all 5 inserts on the diamond disc to get it cutting rather than rubbing and vibrating like crazy. Not a problem of a proprietary insert so much as a quality problem, I think, and they'd be fine if it wasn't for the amount of rake the holder presents them with.
9th Jun 2021, 04:13 PM #855Golden Member
- Apr 2019
- 596
I don't know what brand face mills they are. Took the insets to GeneralTools and they couldn't help unless I could show all the numbers and id off the mills.
