Results 1 to 7 of 7
Thread: Cleaning brass
14th Mar 2012, 06:44 PM #1Novice
- Feb 2012
- templestowe
- 12
Cleaning brass
Hi all,could anyone give me some tips on what sort of bathing solution/mixture I should use to drop brass fittings in and let soak for ease of cleaning.
-cheers-
14th Mar 2012, 07:37 PM #2New Member
- Feb 2012
- kellerberrin WA
- 1
Hi Captn, i do a lot of old furniture striping using a caustic soda
solution , usually brass fittings go in with the furniture. It does a good job of cleaning brass very well . Depending on how bad the tarnishing etc is determines the time in solution, its trial and error , just keep checking. I use a mixture of 500 grams to 5 litres of water. Just be aware to wash down the brass with water first when with vinegar afterwards to neutralize the solution and be sure to wear rubber gloves, this stuff will burn . Hope this is of some help, John
14th Mar 2012, 07:50 PM #3Novice
- Feb 2012
- templestowe
- 12
Thanks John,
had a feeling it'd be something potent or corrosive.I know how lethal caustic can be if ones not careful.I'll give it go.Much appreciated.
capt'n
14th Mar 2012, 07:50 PM #4
Hi Capt'ngrumpy,
I've used this stuff with good results, Metal Cleaner - Surface Prep
A while back my son was playing with different patina effects on brass and bronze, and we got some of this stuff, to clean the brass before appyling different patina's you dip or brush on and after a few minutes it comes out shiny and clean.
Sorry, I've no idea what's in it, but it works a treat for cleaning brass and bronze.
14th Mar 2012, 08:10 PM #5Golden Member
- Mar 2009
- 54
- 825
I always found soaking in just plain vinegar for a day or so works well.
If you want to speed things up a bit just add a couple of table spoons of salt but be a bit careful because this can cause dezinc with some types of older yellow brass.
Rinse with water when done them polish
Greg.
14th Mar 2012, 08:56 PM #6Novice
- Feb 2012
- templestowe
- 12
Thanks Ray, something worth considering.And thankyou Greg,i've heard of something like this before.My oldmans' good mate was restoring his pride and joy HJ Holden(which his had from new)and spent mega bucks on.Dropped the bumper bar in some kind of salt bath;reckons it took it right back to bare metal
ready for buffing and rechroming. Did it with several metal parts from my vague recollection.
14th Mar 2012, 09:20 PM #7Novice
- Feb 2012
- templestowe
- 12
Sorry folks I muffed that last post just a little.I should say FJ holden not HJ.
Minor hickup unless your a car buff, or my oldmans' mate who would be most offended(hj indeed I hear him seethe)
Cleaning brazing "burns" from brass?
By onewing in forum METALWORK GENERALReplies: 2Last Post: 6th May 2010, 10:12 AM
