Results 1 to 8 of 8
13th Mar 2012, 09:16 PM #1
phosphor copper -Where do you get it
Hi
Looking for some phosphor copper rod 0.5, 1, 2, 16mm
Any Ideas any one
Russellvapourforge.com
13th Mar 2012, 09:47 PM #2Golden Member
- Mar 2010
- Nth Qld
- 687
Isn't it available as a brazing filler rod?. you should be able to buy a range of diameters up to about 5-6mm, don't know about 16mm though.
14th Mar 2012, 12:33 AM #3
Hi Russell,
Try George White, and, if googling, look for Phosphor Bronze.
George White | Australia's leading stockist & distributor of non-ferrous metals - Product List
20th Mar 2012, 12:47 PM #4
RayG
Bronze would most likely work also but have not found any small rod yet.
20th Mar 2012, 01:56 PM #5Banned
- Jul 2011
- Melbourne Australia
- 1,376
Russ
Its going to be a long shot, but they use bronze wire in sculptures. There’s a few google hits for artist’s using it here. You might try a good art / craft shop. They might be able to put you on to someplace. Or email one of the artist's.
Phil.
20th Mar 2012, 03:17 PM #6
Hi Russell,
When you say "phosphor copper" I'm taking that to mean "phosphor bronze" , but if this is feed stock for a foundry and you need the higher phosphorous % to make a particular alloy, then I'm wondering why you would want the specific wire sizes...
All of which has got me wondering what you are making...
23rd Mar 2012, 02:02 PM #7
Rayg
The parts go into a vacuum and the phosphors bronze or copper do not gas off
So I am told...........
Go one bite from south america if i would could buy 500kg
Found one in the usa but there hold no stock
Still tiring
23rd Mar 2012, 11:00 PM #8
I don't know enough about the make-up of the bronze, but i can easily get bearing bronze here in canberra. it comes in 1' lengths in all sorts of sizes. it doesn't machine like its oil filled, i can get a spec sheet next time i'm round that way if you like.
Ewan
Working in Copper
By Robson Valley in forum METALWORK GENERALReplies: 10Last Post: 8th Feb 2012, 02:39 PM -
Copper to copper
By slepax in forum WELDINGReplies: 4Last Post: 19th Oct 2008, 04:10 PM
