Results 1 to 4 of 4
2nd Mar 2012, 10:42 AM #1Golden Member
- Apr 2009
- Kingswood
- 930
Metric Left Hand Nut - Fine Thread
I am making a 1 inch shaft to mount a couple of pulleys, a clutch/pulley combination and a bearing to adapt a horizontal crankshaft diesel engine to a vertical drive input ride-on mower using a hydraulic pump and motor.
The shaft stack needs a nut to complete it, preferably a fine-thread LH metric, size about 18 mm.
Any suggestions on where to get a nut, preferably close to Penrith ?
I will be enquiring at Boltmaster today.
I will screw-cut the shaft to suit the nut.
John.
2nd Mar 2012, 10:47 AM #2Golden Member
- Mar 2010
- Nth Qld
- 687
I bought some 16mm left hand nuts from Boltmasters up here, just took two days to get them up with the regular order and cost $5.50 each. The right hand nuts on the other hand were oval, off axis and the six sides of the nut were all different sizes, IOW total crap, I ended up buying nylocks and machining the plastic ring off it and machining a shoulder to get a nice nut if a bit narrower than normal.
2nd Mar 2012, 11:00 AM #3Senior Member
- Mar 2009
- Blue Mountains
- 195
Hello John,
I have a 16mm x 1.5 (fine) LH Nut spare if it is of use.
Will be going through Penrith next week or will be at Mt. Riv. on Saturday morning if you are in a hurry.
Regards Mm.
2nd Mar 2012, 12:41 PM #4Golden Member
- Apr 2009
- Kingswood
- 930
Guys, thanks for the comments.
I got a 18 x 1.5 LH nut from Boltmaster for $5.
Graziano,
I am certainly surprized at your comments on the nut.
My experince with Boltmaster is that the item is always what it appears to be.
Commercial nuts are volume produced, so should be all the same.
I hope you complained.
Metalman,
Thanks for the offer, but I am OK now.
I would be pleased to see you if you want to visit, the travelling steady is now operational and painted (not very well).
Send a PM to organise.
John.
left hand wheel studs
By leopardwood in forum METALWORK GENERALReplies: 19Last Post: 20th Jul 2010, 10:46 AM -
Metric Thread Cutting on Model 9A with Imperial Lead Screw
By Rodd Perrin in forum THE HERCUS AREAReplies: 3Last Post: 21st Sep 2009, 02:14 PM -
Left Hand Thread
By artme in forum METALWORK GENERALReplies: 17Last Post: 8th Jun 2008, 08:50 AM
