Results 1 to 15 of 88
Thread: 17 Leblond restoration?
17th Feb 2012, 01:10 AM #1
I've noticed this machine on ebay for a while now, its almost too cheap to pass up. Large Metal Lathe 17 LeBlond make great wood lathe | eBay
Any comments on the idea of restoring would be appreciated. It would be a big job, but very possibly worth it. The biggest problem would be moving it......
17th Feb 2012, 10:29 AM #2
nice
I think it has potential to be a nice lathe . But it would cost a small fortune to move it , like minimum of $1000 . Cranes would be needed at both ends too load/unload it And , you would need a big shed to keep it in . Older Le Blonds have a very good reputation from what I understand . I used a newer le Blond at TAFE , about the same size as that one . Mike
17th Feb 2012, 11:51 AM #3Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
"Would make a great wood lathe" could be read as 'unfit for intended purpose'. Very close inspection advised.
17th Feb 2012, 04:17 PM #4Dave J Guest
About 20 years ago I nearly bought a lathe like that, but now think back I am glad I didn't. The thing that killed the whole deal was getting a truck crane.
If this is your first you would be better off with a smaller lathe. This one wont have any sort of top speed for carbide and small jobs.
Dave
17th Feb 2012, 05:57 PM #5
I do already have a smaller 10 x 28 machine but would like a larger machine. However moving this would be a far bigger job than the seller makes it out to be. The bed alone is 2600mm long and god knows how heavy. It caught my interest as leblonds tend to be made like tanks......and apparently just as heavy.
17th Feb 2012, 06:17 PM #6Dave J Guest
I had a Hercus at the time I looked at that one, but ended up buying a 12 x 36 lathe some years latter, and it does most ever job I need to do. Sometimes I with I had a bit bigger lathe, but I think no matter what size lathe you have you will always say that, LOL
Dave
22nd Feb 2012, 09:36 PM #7
Oh dear, Another machine.....
When the seller offered to transport it for $300, and sent me some 20 good close up pics i couldn't say no.
I don't think i'm quite prepared for the size of this one, just the thought that i could probably bolt my 10" x 28" in it and spin it round is a bit scarey.
It does seem to be missing the original compound slide, but has a rather home made (or
"agricultural" as my father would say) one. otherwise it is very complete, has original belt driven coolant pump but only a faceplate, so i'll probably spend more on chucks than the machine.
Now i just have to wait till next Friday, or maybe even the one after.
23rd Feb 2012, 01:14 AM #8Dave J Guest
A new machine day is always a good day. Let us know what it's like when you get it, and don't forget the pictures.
Dave
23rd Feb 2012, 09:24 AM #9
24th Feb 2012, 12:29 AM #10
Taster Pics
Here are some of the pics the seller sent me:
The size of it all still eludes me. The spindle nose looks all innocent and small, but from all the internet trawling i've done it should be 2 7/8" 5tpi. Just look at the leadscrew compared to the 3 phase plug, and the thickness of locking plate under the tailstock.
The last pic is of the interesting backgear arrangement. The belt drive LeBlonds have a double back gear, clutch operated, so three belt speeds gives you 9 speeds total.
There also seems to be lube all over the place, hopefully a good sign, its hard to tell with all the dust.
Ewan
24th Feb 2012, 08:40 AM #11Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
It's certainly an impressive lump. Here's hoping there's life in the old girl yet. Will be watching with interest.
24th Feb 2012, 02:58 PM #12Dave J Guest
Agree that is a big lathe.
Dave
24th Feb 2012, 03:44 PM #13
big jobs
Ewan
You should be able to machine car flywheels on that machine
There would be a good value in its scrap weight as well . Not that you would ever consider going down that route
mike
24th Feb 2012, 04:24 PM #14Dave J Guest
24th Feb 2012, 05:05 PM #15Most Valued Member
- 4,890
Was that a loose thread of belting around the joiner,was that a trolley jack on the floor was that a link belt running on the power coed.
260 restoration
By Finnowa in forum THE HERCUS AREAReplies: 7Last Post: 18th Oct 2010, 12:14 AM
