Results 1 to 9 of 9
26th Jan 2012, 09:12 PM #1Novice
- Dec 2008
- 75 km north of newcastle
- 76
- 11
Help with old lathe identification
G'Day
Would any of you knowledgable Metalwork types be able to help identify the lathe in the attached photos. It was given to our local Men's Shed, after languishing for some time behind a nearby farmer's shed.
It has a Compton Parkinson motor which isn't working (although it makes a bit of a noise when switched on). It looks too good to throw away and we are going to try to get it going again, Any help would be greatly appreciated.
Mick Cmañana
26th Jan 2012, 09:49 PM #2Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Hi, sorry I can't help with the lathe - it looks like a lot of old lathes. But what sort of noise does the motor make? I got a grinder from the dump recently that made a loud, harsh vibrating sound, with no motion. I remade the connections in the base (junction box) and now it goes like a charm.
27th Jan 2012, 09:11 AM #3Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Lathe
Cannot identify the make of lathe.
I thought initially it may have been a Drummond, but cant be sure,
Its sad to see old machinery left out to rust.
It could be restored to a useable machine.
regards
Bruce
27th Jan 2012, 10:03 AM #4
home made
The method of construction means, it may be home made . The headstock bearing supports are very flimsy by the look of it.
Just my thoughts . MIKE
27th Jan 2012, 01:58 PM #5Golden Member
- Cairns, Q
- 666
The same thing occurred to me. The tailstock has a bit of a wood lathe look about it. It is rare on a metal working lathe to have an externally threaded tailstock ram.
Hard to tell from the photos, but quite a bit of the metal construction could be welded plate fabrictions.
Frank.
27th Jan 2012, 04:36 PM #6Diamond Member
- Sydney, NSW
- 1,249
Home made or not, its too good to let rust away. If your Men's shed doesn't restore it, put it on Ebay. Someone will buy it.
Ben.
27th Jan 2012, 09:03 PM #7Novice
- Dec 2008
- 76
- 11
Thanks for all of your replies. The motor just gives an internal humming noise - it probably has mud wasps or something gunking up the insides. It will all come out in the wash. In the meantime, I/we will hope someone out there can shed some light on the history of our "Old Lathe". There a still a few pieces missing, eg the front and rear stand/legs or whatever. The tailstock only turned up last Meeting after we asked the donor if he possibly had one (similar to the tailstock on our Hercus) floating around somewhere. He brought it in and said there was still a box of "bits and pieces" that probably are from the lathe.
Mick Cmañana
28th Jan 2012, 04:54 AM #8New Member
- Jan 2012
- Scotland
- 1
You could try Tony at www.lathes.co.uk he has an immense knowledge of older lathes with many photos and original data on his site. I hope that is of some help to you.
28th Jan 2012, 08:00 PM #9Novice
- Dec 2008
- 76
- 11
Thanks Sarpen
That is another avenue to pursue. I will take some more photos of the bearing housings as I believe they are all castings rather than home-made, welded type bizzos. If they ARE home-made, then I take my hat off to the maker.
Many thanks
Mick Cmañana
Lathe identification
By Malibu in forum THE HERCUS AREAReplies: 13Last Post: 11th Mar 2011, 11:15 AM -
Identification For Old Metal Lathe
By chambezio in forum METALWORK GENERALReplies: 3Last Post: 29th Aug 2010, 11:51 PM -
By tanii51 in forum METALWORK GENERALReplies: 18Last Post: 24th Aug 2008, 10:13 PM
