Results 16 to 30 of 529
Thread: Show us your Shaper
12th Jan 2012, 10:02 AM #16Member
- May 2009
- Somerset, UK
- 60
Afraid not - looks like mine has seen harder times, in fact it's overdue for a strip & refit but having just moved house that is way down on the list.
Jordan - I shimmed the gooseneck when cutting the brass gears for a geometric chuck. Can't remember why - but then that's what happens when you get old! - should have made a note.....
MarkWhat you say & what people hear are not always the same thing.
http://www.remark.me.uk/
13th Jan 2012, 02:21 AM #17
Well I just couldn't let this thread go without putting a few pics of my old girl in..
Warning Disclaimer
13th Jan 2012, 10:03 AM #18Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Hey Matt,
The handwheel on the countershaft looks useful.
I like the unusual aerial view.
Jordan
13th Jan 2012, 10:22 AM #19Senior Member
- Salem Ohio
- 219
Here is my South Bend 7" the early version without the oil pump in the base. Prob early 50's. Looked for one that was reasonable for years and found this one 3 blocks from my house sitting under a tarp in a guys auto body shop. He got it with some other machines and didn't want it so i got it cheap 300 bucks. Just needed a stand 2 new belts and some cleaning up...Bob
http://s110.photobucket.com/albums/n...=shaper004.mp4
13th Jan 2012, 12:32 PM #20Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi Bob,
Like you I had the single column support which is next to useless. When I got it it had what was left of a piece of 1" all-thread which the previous owner cut off with a 9" angle grinder. The single support worked well until you used the cross traverse as you know. I decided to build my own making sure the uprighit column could touch the floor but be attached to the base and also be supported by the tray. As the load is vertical the work table just needed a shelf to sit on so I used some 40 x 40 x 5 angle iron which I possibly should have gusseted but didn't reckon getting loads big enough to cause any problems. So far so good. The set-up so far has worked extremely well with some cuts I consider to be on the poor little douglas' limit.
If you need anymore info or material sizes I would be happy to go and measure up for you.
Phil
13th Jan 2012, 01:59 PM #21.
- 6,458
Thank you Phil. I will have a close look at my 10 and see how I could achieve a similar solution.
And here it is, complete with kinky rubber apron and chook cage . Another useless feature on mine was the 1/2" BSW down feed screw. I dealt with that here - http://www.woodworkforums.com/f65/do...ations-129407/
13th Jan 2012, 03:37 PM #22Most Valued Member
- Sep 2011
- Ballarat
- 3,103
13th Jan 2012, 05:36 PM #23Philomath in training
- 6,541
Somthing else to accessorise with
Seeing Bob's rubber apron, you might be interested in this.
Because the tool is always along the same linear path relative to the floor, I made this out of scraps of sheet metal
Attachment 194556
(Actually, another reason was that since learning how to lay out a transition piece in drawing classes, I always wanted to make one. It's taken decades, but it works!)
The chips hit the scoop and then funnel down into the fruit juice tin down the bottom. Makes the clean up that much easier.
Attachment 194557
In position it's roughly centred on the tool path.
Attachment 194558
13th Jan 2012, 05:47 PM #24.
- 6,458
Nice Michael. Something I have thought about and been too lazy to pursue.
13th Jan 2012, 05:51 PM #25
May I drool??
All very nice gear guys
I noticed no one asked what a Geometric chuck is. Mark I found yours the other day was going to e-mail you about it excellent work.
13th Jan 2012, 05:51 PM #26New Member
- Nebraska
- 9
This is a Cincinnati 24" standard. I attached one of those inexpensive 24" Dro electronic scales under the cross axis feed direction since these pics were taken. It has a small display with a magnet on the back and I stuck it in front of the cross feed crank handle.
13th Jan 2012, 08:16 PM #27Philomath in training
- 6,541
Those are beautiful looking machines, although I am deeply suspicious whether they ever get used for anything in such a clean and spacious environment. Admit it - you're the front man for a museum!
(Suspicion fuelled mainly by envy...)
13th Jan 2012, 08:24 PM #28.
- 6,458
Michael,
Have a look at post no.11 in this old thread. -
http://www.woodworkforums.com/f65/ci...ochure-136933/
BT
13th Jan 2012, 10:44 PM #29Dave J Guest
Here is my little 24 inch Alba
It has 6 speeds and clutch. It came with tooling as well as a lot of boring bars for cutting splines internal key ways etc..It had been kept inside a shed and only moved outside for pick up.
And it's 15 inch vice I picked up
This is my 10 1/2 inch Douglas (clutch model). At the moment it is in a pieces getting a good clean up after using it as a surface grinder.It came with a heap of spares like ram, clapper, motor/motor mount, pulleys,lead screw, bull gear, etc.
I am using a milling vice, but I am still looking for a Douglas vice if anyone knows of one.
The Alba has a bit of wear, but the Douglas has only just been run in by the looks of it. I wish it was the other way around because I could fit the Douglas in the Alba if it needed cleaning up.
Dave
14th Jan 2012, 08:05 AM #30New Member
- Nebraska
- 9
Thanks Michael!, Recently I built this new shop with more room. Mostly I use the machines to prototype ideas. After figured out they go to production in another shop. I enjoy the old machines. I added a dro a few months back to that Cincinnati #3 vertical mill and also the dro to the cross feed of the shaper. That helped accuracy of keeping track where I'm at with the shaper.
shaper
By jonroe in forum METALWORK GENERALReplies: 3Last Post: 27th Sep 2011, 12:02 AM -
Shaper
By Anorak Bob in forum METALWORK GENERALReplies: 43Last Post: 19th Mar 2011, 10:18 PM -
TOS shaper
By Bryan in forum METALWORK GENERALReplies: 91Last Post: 16th Mar 2011, 05:58 PM -
or VIC: Shaper
By Bryan in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 11th Dec 2010, 08:06 PM -
Shaper vid
By .RC. in forum METALWORK GENERALReplies: 6Last Post: 1st Oct 2008, 11:03 PM
