Results 1 to 15 of 82
Thread: Installing a hoist
24th Dec 2011, 03:40 PM #1Golden Member
- home
- 621
Installing a hoist
Not sure if metalwork is the best forum but I know I've seen threads on this subject here.
In my new shed, I have an overhead rail made of some tapered flange I beam. I have an lightweight electric hoist - 250Kgs max lift, that I'd like to attach to the rail and I'm not sure what's the best/easiest/safest way to do this.
The flange on the I beam is 75mm and the bolt holes on the hoist are at 90mm.
I was thinking a piece of channel 100mm wide to span the flange with (say) 4 bearings as wheels. I know a proper drawing would help but this is the best I can do.
EDIT: Added picture of hoist and rail it needs to go on.Geoff
The view from home
24th Dec 2011, 03:59 PM #2Most Valued Member
- Sep 2011
- Ballarat
- 3,103
Hi snowy
Try this
Phil
http://www.liftingonline.com.au/products/OZGIRTROLCLA
24th Dec 2011, 04:15 PM #3Golden Member
- home
- 621
Thanks for the link, I hadn't thought of buying one ready made, guess I thought they'd be too expensive.
Looked at Hare and Forbes and eBay and found similar items.
Not sure how I'd attach the winch to it, I'd still need to make some sort of mount to suit the chain hook on the trolley.Geoff
The view from home
24th Dec 2011, 04:53 PM #4Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Can you show us a pic of your hoist?
24th Dec 2011, 05:21 PM #5Golden Member
- home
- 621
24th Dec 2011, 05:21 PM #6Dave J Guest
I made up a trolley to suit one of those electric hoists. I used some flat bar and the wheels off one of those H&F's type girder trolleys.
http://www.woodworkforums.com/f65/ho...photos-113771/
I would recommend buying a trolley new or second hand even if it's only to use the wheels. You just missed out as they where on special for $59 for the 1 ton one.
Dave
24th Dec 2011, 05:29 PM #7Most Valued Member
- Sep 2011
- Ballarat
- 3,103
24th Dec 2011, 05:34 PM #8Golden Member
- home
- 621
Dave J,
Thanks for the link, I remember it from one of the metalworking sites but seem to have missed it here. Hoist is the same as yours but lower rated.
I've found a cheap girder trolley (1 ton) on eBay that looks OK if I can modify it to mount the hoist.
Yet another job that tells me I need to buy a welder (and learn to weld)
I was hoping for a quick/easy solution as I have three sheets of MDF in the van that I can't possibly move by myself. (3600 x 1200 @ 77kgs a sheet) Perhaps I'll work on building the workbenches for the shed, that's a single sheet of red tongue flooring at a mere 35Kgs/sheetGeoff
The view from home
24th Dec 2011, 05:47 PM #9Golden Member
- home
- 621
24th Dec 2011, 06:09 PM #10Dave J Guest
Do you have a picture or a link to the girder trolley you bought?
Dave
24th Dec 2011, 06:14 PM #11Golden Member
- home
- 621
Last edited by snowyskiesau; 24th Dec 2011 at 06:34 PM. Reason: Added trolley picture
Geoff
The view from home
24th Dec 2011, 07:40 PM #12Dave J Guest
Thanks,
It doesn't look like the wheels are attached with bolts like mine was. Have you seen the powered trolleys on ebay for the hoists? They would be a bolt on thing and you would then have it powered as well.
You could attach it to that trolley with 4 short chains and some D shackles, as long as you have the head room. You would need to make up some flat bar plates to go under the 4 outer bolts and have a hole in the other end for the chain.
I remember seeing one mounted, but cant seen to find it. I will have a look around latter for you.
Dave
24th Dec 2011, 08:45 PM #13Golden Member
- home
- 621
The motorised ones look good but outside the budget
No problems with headroom. the girder is just over 3 metres high so plenty of room for chains etc.Geoff
The view from home
24th Dec 2011, 09:12 PM #14Dave J Guest
Thinking about it, I don't think making your own wheels up would be worth it with the trolleys being so cheap.
Another way would be to use 2 pieces of angle bolted along the top of each side of your hoist, picking up all 6 bolts.
Then drill and bolt the other leg of the angles to the sides girder trolley with 4 bolts. This would probably be the better way as long as you can pick up angle the right size. You would have to work out the balancing point so when no load was on it, all 4 wheels stayed in contact with the beam, and the same when lifting something.
These hoists are back heavy, but take the weight of lifting on the front. They seem to get away with the wheels close together on the motorized ones, so you should be right.
Dave
24th Dec 2011, 09:25 PM #15Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Anyone built a car hoist
By simso in forum METALWORK GENERALReplies: 16Last Post: 4th Jan 2011, 09:20 AM
