Results 1 to 7 of 7
Thread: Casting a brass nut.
17th Nov 2011, 07:31 AM #1
I found this interesting; the forge is certainly a lot easier to make than my method of lining an old car wheel with clay!
- Andy Mc (AKA "Ghost who posts." )
17th Nov 2011, 08:24 AM #2Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
Bare legs!
17th Nov 2011, 07:01 PM #3
Thanks Skew for linking to that, safety concerns aside, its a good demonstration that you don't need much equipment to do casting.
19th Nov 2011, 10:02 AM #4Most Valued Member
I know nothing about casting. Well, the only casting I have ever done was to make lead sinkers out of wheel balancing weights found on the road when I was a kid!
So, from purely an interest point of view I found it worthwhile to watch. I just want to go and cast things now.... I have no need to cast anything at the moment but that has never stopped me in the past!
BWT, I'm assuming you would not be able to attain sufficient temps to use it for cast iron?
20th Nov 2011, 08:36 PM #5Most Valued Member
Hi Simon,
Ray does cast iron, his set up it a little more complex.
That set up might get you there, a lid would help.
Not sure why he is reheating and quenching?
21st Nov 2011, 12:20 PM #6Most Valued Member
21st Nov 2011, 01:04 PM #7Senior Member
- Dec 2009
- 327
Often quenching copper alloys from the correct temp will anneal the piece; basically the opposite effect to steel alloys.
Maybe he did it so the polishing would be easier??
I wonder what the nuts were for? Was the thread meant to work or are they ornamental?
A.
what rods for thin brass to brass ??
By Mathuranatha in forum WELDINGReplies: 7Last Post: 23rd Nov 2020, 08:17 PM -
Casting Tools Part 4 - Sand Casting Tools
By RayG in forum THE FOUNDRYReplies: 8Last Post: 9th Dec 2011, 12:03 PM
