Results 1 to 2 of 2
14th Nov 2011, 02:02 AM #1Senior Member
- Salem Ohio
- 219
Milling a 3/16" slot with my lathe.
This is my arbor that i make my SB pulleys in and i make 15 or so a year. Well it needed a 3/16" w x 3/32" deep keyway. I could have done it a dozen different ways but thought to use my 10K lathe and take some pics. I started with my home made square tool block and clamped the arbor in it with a cool looking slide clamp i just had to buy. Then i shimmed up the tool block so the center of the shaft was inline with the #3 MT dead center located in my lathes spindle. I used a steel rule to tell if it needed to come up or go down. Then i raised the block until the ruler was plumb (straight up and down for those that don't know). Then i chucked up a 3/16" end mill in my home made ER40 collet chuck (love that thing) and i tightened the gib screws a twang in the cross slide to keep the chatter down. Moved the belt over a few grooves in the pulleys to get the spindle up to speed for the small end mill and proceded to cut the slot. Took about 5 cuts until it was deep enough to measure with my steel ruler. Perfect fit Here is a small video clip...Bob
MOV02379.mp4 video by aametalmaster - Photobucket
14th Nov 2011, 06:06 PM #2
nice
Thanks for posting that and I like the idea of using the steel rule to centre the job MIKE
Lathe Milling Vice
By wm460 in forum METALWORK GENERALReplies: 2Last Post: 8th Jan 2011, 08:48 PM -
WIP - Lathe Milling Attachment
By Vernonv in forum METALWORK GENERALReplies: 19Last Post: 4th Dec 2010, 01:40 PM -
Milling attachment for lathe
By graemet in forum METALWORK GENERALReplies: 3Last Post: 3rd Jul 2006, 08:48 PM -
Combination lathe & milling machines?
By Chris.s. in forum METALWORK GENERALReplies: 5Last Post: 12th Jul 2005, 04:44 PM
