Results 1 to 13 of 13
Thread: reamers
25th Oct 2011, 08:24 PM #1future machinist
- Mar 2008
- nowra
- 1,598
reamers
what do you guys think about reamers as my local tool shop has a set of reamers they got from china for $150 this consists of sizes 6-20 mm but the tolerances are a mix of h7 and h8 whatever that means.
Andre
25th Oct 2011, 08:40 PM #2Most Valued Member
- 4,887
What type of Reamers are they,Hand,Morse Taper,Chucking ,Adjustable,parallel or spiral flutes.
25th Oct 2011, 08:43 PM #3future machinist
- Mar 2008
- nowra
- 1,598
they are machine reamers i think they are straight fluted.
Andre
26th Oct 2011, 08:15 PM #4Senior Member
- Sep 2008
- Queensland
- 445
If they are sharp and the grinding is good then $150 sounds cheap for a set, If they perform properly they should make drilling and boring to common sizes easier and quicker
Not sure what you mean by tolerances H7 H8 could refer to the steel and it doesnt make sense to mix tools made to different toleranceshappy turning
Patrick
26th Oct 2011, 08:33 PM #5Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
i thought spiral flute reamer's were machine reamers and straight flute reamers are for hand use.
what sort of jobs would u be using them on?
26th Oct 2011, 08:56 PM #6future machinist
- Mar 2008
- nowra
- 1,598
i would be using them to ream pin hole and model engine cylinders so mostly aluminium and brass but also quite a bit of steel.
Andre
26th Oct 2011, 09:58 PM #7
Hi guys the H7 H8 and so on are the tolerance to the size. As for the reamers the tapper reamers are hand reamers and the straight ones are machine most of the time.
Davidgiveitagoturning @hotmail.com
26th Oct 2011, 10:09 PM #8Most Valued Member
- Oct 2010
- 1,910
27th Oct 2011, 07:48 PM #9Senior Member
- Sep 2008
- Queensland
- 445
So what tolerances are the h7 and h8 tools expected to hold under proper use?
happy turning
Patrick
27th Oct 2011, 07:57 PM #10Most Valued Member
It depends on the hole size, but for example using a 6mm to 10mm hole. H8= +.022mm -0.0mm. H7=+0.015mm -0.0mm
Assuming of course I havent gone crossed reading the tables
27th Oct 2011, 08:14 PM #11
Hi Patrick,
As Stuart said... if you have a copy of Machinery's Handbook, or (better) The black book, look it up under "Limits and Fits", H8 is classed as close running fit, and H7 is classed as sliding fit.
27th Oct 2011, 10:09 PM #12Senior Member
- Sep 2008
- Queensland
- 445
My black books at work but I know the table you are referring to,...... Personally I would not get them but maybe go for a good adjustable set........ still $150 sounds like a good price if those fits are what you are after
happy turning
Patrick
27th Oct 2011, 10:42 PM #13future machinist
- Mar 2008
- nowra
- 1,598
well i am not sure as i found a second hand adjustable reamer set made in Melbourne with sizes up to 1 1/16 for $180
Andre
where to get reamers etc.
By holmsy2000 in forum METALWORK GENERALReplies: 10Last Post: 16th Nov 2006, 02:23 AM
