Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Apr 2012
    carrum
    51
    Nice Job I guy in I know in Melbourne who also has a CVA, I thought his was a Monarch EE at first sight. No comparison between the CVA and the HF machines which are all spindle speed challenged and a little flimsy in the sub $10K models. The 10EE motor is good the thyratron speed controller is as antiquated as a valve television Not difficult to replace it with a modern controller though some EE owners would consider that sacrilege.
  2. #17
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    Yes, couldn't see anyway around the supply issue. While you can get 20 and even 30 Amp single phase supplies in Aus that would give the power required, the problem then becomes finding a VFD that will turn that into 3 phase. I read that you can supply single phase to 3 phase in VFDs but that you have to derate them quite a lot, so potentially I could have needed say a 10kW unit, and they are industrial units so would not be cheap either.
  3. #18
    Nov 2008
    Perth WA
    6,459
    Nice lathe Michael. Tasteful restoration.
    I have only seen one of the older Monarch-esque CVAs. A thing of beauty. I used to think squared off was less appealing than curvaceous but notions can change when viewing something first hand. Quality comes to the fore, often eclipsing preconceived ideas about shape.
    Bob.
  1. SOLD: Lathe for Lathe Drill Mill (Near Liverpool NSW)
    By Auskart in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Jun 2010, 07:02 PM
  2. Buying a lathe (Old massive Lathe, or New small C6 Lathe)
    By Ch4iS in forum METALWORK GENERAL
    Last Post: 25th Mar 2009, 12:19 PM
