Results 1 to 5 of 5
Thread: Centre Height Gauge
1st Sep 2011, 10:50 PM #1
Centre Height Gauge
After fiddling around making a small boring bar, I finished the centre height gauge I have been working on for a couple of days. All in stainless steel. Top bolt adjusts height then side one locks it. It is not easy to see but the top piece started as hex. I cut bottom flat and top angle by mounting it in the 4 jaw. Also drilled and milled and tapped hole at same time. The clamping thread was already there. I have ordered some 10mm x 1mm magnets from ebay. If they are strong enough I will bore a hole to suit in base to hold it down. Sorry about the jaw marks (smack).
Attachment 180841
Attachment 180842
2nd Sep 2011, 01:57 AM #2.
- 6,458
Dean,
I knocked up a similar device a while back. http://www.woodworkforums.com/f65/simple-lathe-tool-centre-height-gauge-129620/
It's a useful bit of gear made more useful because my lathe has an extended cross slide. Conversely, it's next to useless on my Hercus with the standard cross slide. On that lathe I still fool around trying to align my cutters with the tailstock centre. Your little gauge would sit nicely on the ways and the inclusion of a magnet would ensure it stayed there. A neat idea and one I should copy.
Thank you.
BT
2nd Sep 2011, 10:53 AM #3Diamond Member
- Mar 2011
- Dural NSW
- 82
- 1,203
Lathe Centre Height Gauge
Bob
Thanks for the info on your Lathe Height Gauge & the photos of the Hardinge design.
If you do not have a patent on yours & you dont mind, I will copy yours.
There have been many times when I have had a need for a Centre Hight Gauge on my Lathe.
regards
Bruce
2nd Sep 2011, 07:33 PM #4
I think it was that thread that made me decide to make one. I also have been using the tailstock centre. With my cross slide the ways were the only logical surface to use. There is a flat surface on the carriage but I felt it would be more awkward to line up to it. On the ways I can move the carriage and rotate the post to line up. Easy. I should try it out. I haven't used the lathe since. I engrave each tool with its mounting height so I can work out the spacers needed. Usually this is enough as all my spacers have the thickness marked as well. The diamond holder needs a gauge tho.
2nd Sep 2011, 07:44 PM #5Most Valued Member
I've got the old style tool holders which hold 1/4'' HSS blanks at an angle of about 15 degrees to the horizontal. That means every time you move/replace/grind the HSS tool you change it's height. I reckon I could use some sort of height gauge.
SOLD: Starrett C 454 M Vernier Height Gauge
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 11Last Post: 2nd May 2011, 06:04 PM -
Simple Lathe Tool Centre Height Gauge
By Anorak Bob in forum METALWORK GENERALReplies: 6Last Post: 14th Jan 2011, 05:17 PM
