Results 2,326 to 2,340 of 2682
Thread: todays tools gloat
19th Feb 2020, 10:05 PM #2326Most Valued Member
- Healesville
- 2,129
Small drills.
The smallest drill in this chart is 1/32" and recommended max speed = 36672 rpm for aluminium
https://www.imperialsupplies.com/pdf...t_PRMChart.pdf
I have a set of jet drills, the smallest drill in the set i can barely see now.....
19th Feb 2020, 10:18 PM #2327Member: Blue and white apron brigade
- 7,183
I have a set of drills I use for electronics projects that go down to 0.5mm (and SWMBO has some even smaller for her jewelery stuff) I’ve use some of mine with a Dremel @ ~25k rpm. The higher speeds make a real difference. Better in a DP though as it means work and bit can be help at same position so less chance of bit breakage.
19th Feb 2020, 10:19 PM #2328China
- Dec 2005
- South Australia
- 1,656
Jewellers and watch makers use high speed sensitive drill presses all the time one reason this thread interested me is I have a sensitive drill press
the same colour I am trying to discover the maker
21st Feb 2020, 10:05 AM #2329Senior Member
- Nov 2019
- Brisbane
- 69
- 452
21st Feb 2020, 10:33 AM #2330Senior Member
- May 2019
- Picnic Point, Sydney
- 77
- 312
I was given a packet of .006" micro drills that were used for drilling cornea implants ... never used as I don't have a high speed drill. Looking at them through a microscope you'd swear you're looking at a 1" drill the detail is that good. Hopefully this link showing their manufacture works. https://www.youtube.com/watch?v=G55kLhv2d_4
23rd Feb 2020, 03:43 PM #2331Senior Member
- Nov 2011
- Port Sephens NSW Southside
- 123
Moore & Wright, and others
Picked these up a few days ago. Deceased owner was a tool maker. One of the calipers has his name on it with 41 after it (year). Those 2 large calipers are 16 inch.
Pic 05a - All M&W.
Pic 54a - Pastorino Circlip pliers, Eclipse 235 toolmakers vice, other vice unmarked, could be from apprenticeship, bottom left I think is another toolmakers vice.
Pic 07a - Pipe flare, M&W Surface gauge, Rockwell chuck ball & Test Blocks 27 & 62, various clamps & engineers jacks.
JohnQ
23rd Feb 2020, 08:16 PM #2332Senior Member
- Nov 2011
- 123
Thanks Grahame
Spent 3 or so days sorting the garage out & cataloging tools, So got a good deal, seeing the family didn't want anything. It was going to be given away to friends, I said no way.
Some of the tools had some surface rust, but came up pretty good with a light touch of the Carbide scraper.
Her father was a Fitter & Turner / Tool Maker for the N.S.W Railways from 1940-85 when he retired.
I have 2 friend who are into vintage cars coming around on Wednesday to have a look at some sockets & spanners & an 8 inch Centurion (Alltools) bench grinder.
24th Feb 2020, 06:59 PM #2333Senior Member
- Sep 2019
- Newcastle, AU
- 238
Got lucky and scored this Australian-made grinder:
As usual, working on a history page for the manufacturer. It's one heck of a unit - bigger and heavier than the 3-phase 1hp GMF I restored at the end of last year.
24th Feb 2020, 08:41 PM #2334
Hi JC,
It looks like it has decent tool rests on it, unlike the rubbish we buy today !Best Regards:
24th Feb 2020, 08:58 PM #2335Most Valued Member
- Charlestown NSW
- 1,669
Would not surprise me if they were related to GMF. The base and tool rests look identical to a similar size and vintage GMF.
Nice looking old thing. I think they had some at Vales Pt Power station when I was workign there back in the day.
peter
24th Feb 2020, 08:59 PM #2336Senior Member
- Sep 2019
- Newcastle, AU
- 238
Originally Posted by BaronJ
Good eye - they are related - John Durst was one of the founding three directors of GMF, as I found out when I did the history here:
https://motofaction.org/tool-reviews...ishers-mowers/
24th Feb 2020, 09:25 PM #2337Most Valued Member
- Charlestown NSW
- 1,669
24th Feb 2020, 09:28 PM #2338Senior Member
- Sep 2019
- Newcastle, AU
- 238
I'm having trouble dating this grinder at this point, but I know where there's a stash of Durst catalogues that will help - here's hoping I can get hold of them.
GMF came into being in 1940 and Durst 1918, for what that's worth... the only Durst ad I have found online in advertising is a very poorly scanned one in 1948 and it could be a match for what I have here, but it's darn hard to tell. Waiting on better info. Got a photo of your GMF?
I'm pretty confident at least one of the GMF grinders I have here is older than this Durst - reminds me, I need to date the Junior GMF grinder...
24th Feb 2020, 09:45 PM #2339Most Valued Member
- Charlestown NSW
- 1,669
24th Feb 2020, 10:38 PM #2340Senior Member
- Sep 2019
- Newcastle, AU
- 238
