Results 1 to 15 of 22
24th Aug 2011, 02:59 PM #1Novice
- Aug 2010
- Brisbane
- 11
Can I get Custom Lathe Work Done?
Hi all,
I hope this is not inappropriate to post here ( I read the stickies about posting rules and it’s not mentioned…I hope) so here goes…
I need a custom piece of metal made up for me. I don’t have access to equipment let alone the knowledge and skill to make it myself. I have searched for machine shops here in Brisbane but when I remembered these forums I thought why not ask.
It’s a bit hard to describe at this point as I am not fully decided on the dimensions or material to be used yet. I figured it’d be better to find out what I can get before going about designing something way too complicated to get machined!
Long story short it’s a rotor for a brushless electric motor I am modifying. All it is, is a steel tube with an outer diameter of roughly 100mm with a 10mm wall thickness. The tube would be about 40-50mm long. It will need (at this stage) 12 flat faces machined onto the outside of the tube where the magnets will be attached. The 12 faces will likely be separated (so the edge of each flat section will not be touching the edge of another – flat, curved, flat, curved etc).
Ultimately I want to weld this tube to the attachment plate of the old rotor (that I have ground off) so some care will need to be taken to provide a welding surface. But that’s by the by at the moment.
I realise my knowledge on what is possible is limited so if someone is willing and able to do this for me I will gladly sit down with them (or via email) and nail out exactly what I want vs. what can be physically accomplished…and of course nutting out the dollars required for your time!
Alternatively if someone can recommend a better way of going about getting the piece I require made I’m all ears!
Any information would be greatly appreciated.
Regards,
- Matt
24th Aug 2011, 03:55 PM #2Most Valued Member
- 4,890
I dont mind having a go but I"m in Sydney,you may get offers closer.
24th Aug 2011, 04:18 PM #3Novice
- Aug 2010
- Brisbane
- 11
Hey no worries. If no one else replies I'll be in touch
Just to add some detail - the actual wall thickness is up for discussion. The total OD of the tube is the important part (so it fits inside the motor) but the thickness can be whatever is easiest. 10mm is only a suggestion because the magnets need a solid backing for them to perform their function correctly.
Anywho...I'll sit and wait
24th Aug 2011, 04:49 PM #4Most Valued Member
- 4,890
If no else takes it up,the rest without seeing a drawing should not be a problem,only concern may be material choice and possable distortion from welding.
24th Aug 2011, 06:04 PM #5Novice
- Aug 2010
- Brisbane
- 11
n the interest of making this a bit better I'll actually sit down and draw some semi-decent pictures tonight.
Your comment on the rotor warping with the application of heat is something I never considered but it does make sense. Maybe a better idea for me to get done would be to completely replace the existing rotor with a totally new part. This would allow me to save weight, and build (in my opinion) a more robust and better suited replacement.
I'll put my thoughts into writing/visio drawings and post it back here later tonight.
24th Aug 2011, 06:17 PM #6Member
- Mar 2011
- Brisbane
- 56
I might be able to help out as well.
I would need some idea as well as to how accurate the spacing of the twelve flats would need to be. +- 1 degree is not to hard +- 0.01 is very difficult.
Probably best to weld the rotor together then do final outside machining and flats.
Dave
24th Aug 2011, 06:18 PM #7Most Valued Member
- 4,890
Good idea,seeing I have no real idea of what the end result will be you may be able to get away with having a thicker wall section at the welded end to help eliviate distortion,or possably a thinner section so that less heat will be generated when welding.
24th Aug 2011, 06:30 PM #8Most Valued Member
Hi,
I'm even further away the PC but I'm just watching out of interest.
What sort of rpm will it be doing?
24th Aug 2011, 08:41 PM #9Novice
- Aug 2010
- Brisbane
- 11
I have an offer from someone in Brisbane to help me so I'll see what he can do. I will however post everything here just in case it falls through/for people who are interested.
I should stop screwing around and give all the details and let the people with a bit more knowledge than me come up with the best solution.
I am re-purposing a truck alternator as a BLDC motor. It's been done before and I'm attempting to do it better. No other reason than I'm inquisitive by nature (I'm an Aerospace Avionics Engineer by profession) and....because I can . It's a little project of mine basically. Beside - if it works as well as I think it will I can use it to power some insanely fast go-karts/bikes.
Part of the process is to remove the old 'claw' style rotor and replace it with, as previously mentioned, a permanent magnet rotor. This increases power, and removes the need for brushes in the motor to charge the rotors electromagnetic coil.
Here are photos of the existing rotor, still on the axle. I need to remove the rotor from the axle but I was having problems tracking down a set of clamp pliers (or whatever they are called) to remove the split ring in the open end (sort of visible in the first pic):
(Argh...NFI why they won't display in the thread itself.. )
Anyway. The rusty rotor claw and the large inner tube (that is solid) appear to be 2 different parts, though I cannot tell how they are held together.
What I need made is exactly what is there now, but with the claws replaced with a hollow tube about 10mm thick and with the 12 flat spots. The large solid inner tube could be less thick I'm sure of it. This would reduce the weight. I'm not totally sure why it's so thick - without reading up on my alternator theory I'm assuming it's to maintain spinning momentum in order to smooth out sudden increases and losses in rpm. This is not an issue in a motor.
This will need to spin at around 4000 - 6000rpm, though that is entirely dependent on the Kv (rpm per volt) of the motor (an unknown quantity at this stage) and the ESC (electronic speed controller) I use. I'm more worried about the magnets coming off than the rotor tearing itself apart.
Could this be made from one piece of steel? The 'backing plate' the would connect the 2 tubes can be solid with a few holes drilled in it for ventilation. Or maybe it could be 3 parts, welded and then rounded up nicely on the lathe? The most delicate part would be replicating the depression for the clip ring. but even that would appear to be fairly straight forward to me. But what would I know! Just some ideas...
As for accuracy - in this sort of application the closer the better. However +/- 1 degree is excellent, anything better is superb. I will get the flat spots to be machined a few mm wider than need be to give me room to move the magnets around before epoxying them in and wrapping the thing in carbon fiber. That's the only way they will stay put at 6000rpm.
Hope this clears some of it up. When I get the existing rotor off the axle I'll report back.
Cheers and thanks for reading.
24th Aug 2011, 09:04 PM #10Member
- Mar 2011
- Brisbane
- 56
Looks like you could machine the claw assembly down so the new tube goes over the top.
This can be done with no dissassembly required.
You can then weld the tube to the remains of the claw assembly.
Then machine the OD.
Dave
24th Aug 2011, 09:11 PM #11Novice
- Aug 2010
- Brisbane
- 11
If that's the easiest way to go about it then I'm all for it.
The only problem might be that the claw is a very tight fit at the moment (inside the stator) and once you machine that down and take into account the thickness of new tube (5-10mm) and the magnets (between 3 and 5mm) it might be too large. If you machine it down far enough to fit you might not have anything to weld the new tube to other than the existing backing plate.
Though to eb fair that was my initial idea and looking at it now it might work. Though I can't stress enough that the thicker the tube the magents attach to, the more effective the magnets will be.
If that makes sense?
24th Aug 2011, 11:49 PM #12Novice
- Aug 2010
- Brisbane
- 11
OK I've sat down and done the numbers on the flat surfaces required to be machined on the outside of the main tube.
The easiest solution (but not ideal) I came up with was a flat surface 19mm wide every 30 degrees.
The ideal solution (though it may be too difficult to implement) is a flat surface 6.4mm wide every 30 degrees. Either side of this is another flat surface the same width. So groups of 3 flat surface every 30 degrees.
If the second proposal can be made it would very much be appreciated.
Please see some rough sketches below. I realise the width of of the flat surfaces on the 3-group design seem almost pointless and I have considered it but I feel the magnets need as close to 100% surface contact to work properly.
I should also point out that this rotor will only be 38mm in length...so it's actually quite small.
Brain fart time:
I could also always just do the 19mm wide design, and place a thin piece (1mm thick) by 7mm wide steel in the middle of the flat spot. The middle magnet would be raised and the 2 side magnets could sit half on/half off to angle them out slightly. This would give near the same result as the more difficult to machine design without the difficult work involved.
Also in regards to racer123's idea of machining the claws down and welding the tube over the top...would it be just as much work to machine the claws completely off and then weld the tube to the 6 'stubs' that are left? This would also give the opportunity to remove some of the metal off that large inner solid tube as well (if this can be done) to reduce the weight a bit because it is ridiculously heavy.
Let me know what you all think. Do-able or completely out of touch with reality?
Cheers.
25th Aug 2011, 12:01 AM #13Novice
- Aug 2010
- Brisbane
- 11
Also I've tried replying to a PM stix012 sent me. After I hit send I would think the message would show up in my sent box. But it's not. So if you're not receiving them what the? But if you got 3 copies of the same email...whoops, though I have no idea what I've done if that is the case.
25th Aug 2011, 12:05 AM #14Most Valued Member
Those claws look cast, welding to them would be a problem if they are.
Flats 7.5 degrees apart shouldnt be a problem.
Are they round magnets? maybe a row of holes drilled with a slot drill would help hold them in place better?(although this would take alot longer.)
How are you going to balance this?
25th Aug 2011, 12:07 AM #15Most Valued Member
Did you tick this box down the bottom of the page? "Save a copy of this message in your Sent Items folder."
Finding someone for custom work
By tianakaesha in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 10Last Post: 17th Aug 2011, 11:34 PM
