Results 1 to 6 of 6
Thread: CNC Router
5th Aug 2011, 07:22 PM #1
CNC Router
Hi Guys.
A friend has a CNC router and has been making me some buttplates out of 4mm Ally. The edge has some chatter even though he did it in four passes 1mm at a time. He is using a 3 or 4mm bit at about 24000rpm.
Any ideas please.
Kim
5th Aug 2011, 08:13 PM #2
Hi Kim,
Lighter cuts, especially the finishing cut, maybe 0.1mm, rather than 1mm.
The chatter is most likely being caused by tool deflection.
5th Aug 2011, 08:35 PM #3
Thanks Ray.
The 1mm was deep but I get it.
tool deflection was my guess so mabe a larger dia cutter
Kim
5th Aug 2011, 08:37 PM #4Golden Member
- May 2003
- 526
If the edges are what I call gummy it is remelt and a coolant should be used. At 24,000 RPM you generate a lot of heat unless you have a good chipload which takes the heat away. A spray of WD40, CRC or your own brew will help.
It the edges are smooth but have toolmarks then it is deflection of the tool / machine or the head needs tramming depending on how the marks are arranged. If a 3mm bit is being used then likely to be deflection in the tool. One method is to offset the cut 0.1mm and cut the job in increments and then do a full pass to your line. You will need tabs to do this.Cheers,
Rod
5th Aug 2011, 09:16 PM #5Most Valued Member
What sort of cutter are you using?How many tooth?
I assume you are effectively cutting a slot around the butt plate?
What feed per tooth?
7th Aug 2011, 05:57 PM #6
Thanks Guys
I think it is a one tooth cutter but it is not my machine just my job and he is new at ally. He is a kitchen man on the day work and whatever at night.
Kim
