Results 1 to 5 of 5
1st Aug 2011, 12:05 PM #1Golden Member
- victoria
- 499
Hi From Victoria . I need some parts for my Advance lathe
morning too all forum inmates.
I have an old advance lathe that need a 3 Jaws Chuck . the spindle hole is 1" / 10tpi .
any one here might have a spare one or know where i can get one ?
Peter
1st Aug 2011, 12:17 PM #2Most Valued Member
- 4,887
Can you turn the thread and make your own backing plate.
1st Aug 2011, 12:45 PM #3Golden Member
- victoria
- 499
advance lathe 3 jaws chuck
no i don't have enough skill to do that . any one might be in Victoria ?
cheers
Peter
1st Aug 2011, 12:53 PM #4Golden Member
- Cairns, Q
- 666
Hi Peter,
See:
http://www.woodworkforums.com/f65/su...ate-oz-119159/
Note that the Advance spindle is 1"x10 TPI BSF thread, which has a 55 degree thread angle and Whitworth thread form. Some American sources advertise 1"x10 backplates, but these are almost certain to have the 60 degree unified thread form thread, so would probably not be a satisfactory fit on the Advance spindle. As mentioned in the previous thread 1"x10 BSF used to be a common spindle nose thread on wood lathes sold here, so you might find something suitable for a backplate at a woodworking tool supplier. Failing that, your best bet is probably to have one with the correct BSF thread form made.
Frank.
Edited after I saw your reply to Pipeclay.
F S
2nd Aug 2011, 11:52 PM #5Senior Member
- blackburn vic
- 297
Back when I had my Advance Lathe I made my own backplate.
I got a 1" BSF nut, welded a suitable piece of plate onto it then turned and faced it on the lathe. The tricky bit is drilling the holes to mount the chuck correctly. It can be done, with a little bit of care.
Roger
Need parts for lathe
By Bart in forum METALWORK GENERALReplies: 21Last Post: 30th Jan 2007, 11:39 PM
