Results 1 to 11 of 11
Thread: Tool post grinder
21st Jul 2011, 02:59 PM #1
Tool post grinder
Spotted this :
LittleMachineShop.com - Tool Post Grinder (220VAC)
I like the variable speed, but the motor looks a little small and underpwered . There is another smaller one there that looks like it has a sewing machine motor on it .
Mike
21st Jul 2011, 06:58 PM #2Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI,
You will find some Plans if You go to this Link http://www.woodworkforums.com/f65/to...-plans-138306/ . The Link is to a recent Thread that I started.All The Best steran50 Stewart
21st Jul 2011, 07:09 PM #3
thanks
Yes I spotted it ... very interesting . I posted a link to your plans on the Southbend Yahoo group .. 1930's technology still works
Are you making that particular Grinder yourself ??? Where would you source a motor like that ?
I did a TAFE lathe course last year ..I recomend it , but may be to far for you ....
21st Jul 2011, 09:01 PM #4Diamond Member
- Sep 2006
- 53
- 1,010
HI,
Since seeing those Tool Post Grinder Plans I have done more Research and have decided to make a 1/3hp (250watt) Tool Post Grinder. I am looking at using a Quorn Motor Quorn Mk 1 - 0.18Kw 240v 2800rpm Mark 1 motor - Hobby Mechanics or I might see what Royce Cross has available. Although the Quorn Motors are listed as 180 Watt, I bought one motor of them late last to build a Quorn and it was 250 watt.
Since I am going to Build a bigger Tool Post Grinder I will be designing something Myself - No doubt I will use ideas from existing Designs.All The Best steran50 Stewart
21st Jul 2011, 09:31 PM #5Most Valued Member
- Oct 2007
- 3,112
Mike I was considering that TPG myself and from what I heard it was "ok". Like a lot of Chinese tools like this, a bit of a "kit" when it's unpacked, but a good base on which to improve. Getting it out from the US however isn't cheap. While I was poised to buy it, in the end I've decided not to get a TPG and will probably make other arrangements when I need to do work like this.
I do like the way a drill chuck can be fitted for cross drilling in the lathe. I have another fixture to hold a Proxxon drill, it works extremely well but I am very limited with the size drill bits I can chuck in it. This TPG would enable a much larger drill chuck to be used.
Pete
21st Jul 2011, 10:08 PM #6.
- 6,458
I don't know if you blokes have looked at some of the old posts related to TPG's but here is one about my Dumore 44 and the fun and games involved in trying to acheive an acceptable finish. http://www.woodworkforums.com/f65/to...51/index2.html It may be of some interest.
If do end up buying or making your own, make sure everything is covered up when you use it. The destructive grit goes everywhere.
BT
22nd Jul 2011, 12:57 AM #7Dave J Guest
LMS had a clearance on the smaller grinders a few months back, I think they where $80. The people that bought them seemed happy with them.
Dave
22nd Jul 2011, 06:15 PM #8
Anorak BOB
I read your posts .. I recall seeing a home made TPG a chap in the UK had made . After extensive research and work, he found the best results from a grinder he built with plain bushes rather than ball races .. he tried all types of designs ..but the plain bushes beat everything
Mike
22nd Jul 2011, 09:28 PM #9Distracted Member
- May 2010
- Lower Lakes SA
- 58
- 2,607
This one?
[ame=http://www.youtube.com/watch?v=d-woPRV_lac]‪Toolpost grinder‬‏ - YouTube[/ame]
23rd Jul 2011, 05:20 PM #10
Yes
YES thats the one ....
I wondered about using a universal motor from a domestic sewing machine - they will run from both AC and DC , unusual motors and they lend themselves to easy speed control .
Silicon Chip Online - 10A Universal Motor Speed Controller, Mk.2
The problem is , not enough OOMPH . Maybe two working together would work . OP shops are full of old sewing machines with those motors
Sew-Classic Blog: Comparing Sewing Machine Motors in Simple Terms
How real electric motors work
MIKE
23rd Jul 2011, 08:44 PM #11
Ideas
lots of ideas here
Toolpost Grinder
this motor is interesting
https://www.petenplanes.com.au/field.../prod_865.html
Tool post grinder plans
By steran50 in forum METALWORK GENERALReplies: 6Last Post: 18th Jul 2011, 10:33 PM -
tool an cutter grinder maybe???????
By tanii51 in forum METALWORK GENERALReplies: 2Last Post: 1st Jul 2011, 09:30 AM -
Waldown tool post grinder
By Stustoys in forum METALWORK GENERALReplies: 25Last Post: 20th May 2011, 01:50 AM -
Grinder Tool Rest
By wheelinround in forum METALWORK GENERALReplies: 16Last Post: 4th May 2009, 10:09 AM -
Tool Post Grinder & Myford Lathe restoration
By DSEL74 in forum METALWORK GENERALReplies: 3Last Post: 10th Dec 2007, 12:23 AM
