Results 1 to 15 of 15
Thread: Need Sheraton Conquest info
2nd Jul 2011, 10:44 PM #1Senior Member
- 27
- 248
Help finding Sheraton Conquest metal lathe info.
Hey, im looking for info and pictures on the Sheraton conquest lathe. So i wanted to know if any of you guys know of any info on the Sheraton Conquest metal lathe because i cant find a single thing, the only thing i could find was that it is a gear headed version of the south bend 10".
Cooper
3rd Jul 2011, 12:43 AM #2Senior Member
- Jul 2007
- 112
Sheraton conquest headstock
Having recently restored my conquest, I inspected inside the headstock to check the condition of the gears and any wear. The photos show a well designed and solidly constucted headstock. Three of the gears are of the fibre material, which account for the silent running. Wear was not noticed on the gear spurs. The spindle bearings are timken taper roller, class 3 tolerance. The spindle mount is camlock D1-3, not a common size.
I can supply more photo's of the finished machine in a later post.
Peter
3rd Jul 2011, 12:44 AM #3
Now please don't take this the wrong way but I would suggest that you get the money together ($600-$1500) and then look at what is available in that price range. Looking around without ready cash will only lead to disapointment. Lathes will be around for a lng time and who knows the exact one you are looking for will turn up and then as you have the cash you can buy it and not worry that it will be sold before you can save up the money
PeteBoycott Shampoo!!
Demand Real Poo!
3rd Jul 2011, 12:53 AM #4
Hi fxst,
Just to bring you a little more up to date on the story so far, Cooper (xXvapourXx) has already been kindly offered a Sheraton Conquest by Eric (erickendall) very generously free of charge, an earlier thread has more of the details... the latter portion of this thread http://www.woodworkforums.com/f65/lathe-anygood-136905/
now read on...
3rd Jul 2011, 01:15 AM #5Senior Member
- 27
- 248
Peter
The three gears made from fiber metal, are they stock or did you buy new ones because i might buy some for silent running since i live in area with lots of houses surrounding and so i can use it during the night without bothering people.
Quote:
Pete
Hi fxst,
now read on...
Peter
Cooper
3rd Jul 2011, 11:51 AM #6Senior Member
- Jul 2007
- 112
The headstock was found to be in pristine condition, as the photo's show. I did not need to touch the gearbox or the spindle bearings, simply changed the oil.
If you look at the design of the gearbox, the size of the gears are massive compared to modern day products. These lathes were built to the highest standards of the day and in small numbers. The close machining tolerances, quality materials and a conservative design mean that they will last. As far as I know, the conquest model was supplied to the army as a training lathe, not sure how many are about. But they are quite rare.
So obviously it is worth the effort to restore properly, as I know you will.
I can help with any info to get you going, let me know what stage you are at.
Regards,
Peter
3rd Jul 2011, 02:37 PM #7Senior Member
- 27
- 248
I thought they would be pretty rare seeing that theres barely any info on the lathes but the only way to really find out about these lathes are really to ask the owners, another cool thing is that hearing from some other owners including brittle is that some of these lathes were made for the army for training. With oiling the parts what oil is good to use? 1 to 10 what would you rate this lathe for sound a quality?
3rd Jul 2011, 02:53 PM #8
aaah ok. I hadn't seen that. I just didn't want a young aspiring machinist to get dis-heartened and give it away. Nice to know people still try and help out. I reckon thats a great donation and hope karma is returned
Demand Real Poo!
3rd Jul 2011, 03:36 PM #9Senior Member
- Jul 2007
- 112
I think its a bit subjective to rate any of the better machinery, it's "what it can allow you to do" that is important. It will be accurate enough for most requirements (within its size), but keep in mind the other important things. Good sharp tooling, learning to sharpen the tooling, safety and a good understanding also count. There is plenty of people willing to give advice on this forum, most from years of experince, so ask away. Many would be able to get a 10/10 result from a lathe, when others would struggle.
Put it this way, if it is cleaned up and adjusted properly and has not been damaged, it will be fine. GL Sheraton used to make parts for Colchester lathes, so I wouldn't be concerned about quality.
You asked about types of oil? This will no doubt open a hornets nest of replies, I would be more concerned at dismantling and cleaning the parts that get dirty first. I have photo's of some parts and they are easy to work on.
A couple of suggestions: Leave the headstock alone for now, its is sealed. If taking the apron apart, the srew in the clutch is LEFT hand thread. The lathe bed is hardened, be careful not to use abrasives to clean up. Steel wool is OK, but a green scrubbing pad can scratch. I used WD40 or CRC with rags to clean. A coat of mineral oil is good to stop corrosion after cleaning.
Thats a start,
Peter
3rd Jul 2011, 04:15 PM #10Senior Member
- 27
- 248
I dont have the lathe as of yet but I like to do my research before I get something so hopefully I can reflect back on this topic when I get this lathe and I might make a video on building it, I hope it will help others to.
When I get the lathe what should be the first thing to do other than building it?
3rd Jul 2011, 05:42 PM #11Most Valued Member
- 4,890
Would probably be best to lay the parts out where they belong along the lathe bed.
If some parts are dissasembled eg the carriage put parts to gether and photo them someone will let you know what goes with what.
Probably a great idea to learn the name of the main parts of the lathe so if you do have a question people will know what you are talking about.
Hopefully the member you pick it up from will either have the parts grouped to where they are from or will be able to tell you so you can put them together in cardboard boxes.
3rd Jul 2011, 06:32 PM #12Senior Member
- 27
- 248
e.g. Box 1 carriage, box 2 gears etc
Pete
Cooper
3rd Jul 2011, 07:22 PM #13Senior Member
- Jul 2007
- 112
Here is a parts manual for the conquest.
Peter
3rd Jul 2011, 08:26 PM #14Senior Member
- 27
- 248
25th Jul 2012, 12:37 AM #15future machinist
- Mar 2008
- nowra
- 1,598
Is the concensus that these are good lathes theres one for sale 10 minutes from my house for $900 I'm half tempted.
Andre
sheraton conquest lathe
By leopardwood in forum METALWORK GENERALReplies: 11Last Post: 7th Jun 2010, 08:59 PM -
sheraton A steady?
By danielhobby in forum THE HERCUS AREAReplies: 3Last Post: 13th May 2010, 01:49 PM -
Sheraton lathe. Need some pull it apart info...
By _AL_ in forum THE HERCUS AREAReplies: 4Last Post: 3rd Mar 2010, 07:36 PM -
Sheraton Lathe
By electrosteam in forum METALWORK GENERALReplies: 4Last Post: 9th Jul 2009, 11:38 AM
