Results 1 to 2 of 2
Thread: Lathe recommendation
28th May 2011, 10:19 PM #1
Hi all,
Just seeking some input/advice.
I am looking at getting a metalworking lathe. Only after a small one for model work and small parts (I mainly build model ships and some othersmall projects, and hang out on the woodwork side of the forums mainly). I also want something lower-end pricewise.
So I am looking at the C1 or C2 lathe (Sieg, Carbatec & Hafco all seem the same). However have also seen the Sieg N1 Nano lathe (100mm between centres & 100mm swing). The Nano looks OK but low power, limited size (may not be an issue) and round lathe bed bar may not be as accurate as a flat cast iron one).
I know that a bigger lather can do smaller work, so will be limited with a smaller lathe, but lack of both money and space mean I'm looking at these smaller models.
So - I'd be interested to hear the thoughts of people with actual metalwork exerience what they think of these? Are the 1/5 hp motors underpowered (I'll mainly be turning brass and aluminium)? Are they OK generally?
I appreciate any thoughts, feedback or advice.
Regards,
Darren
29th May 2011, 12:25 AM #2Most Valued Member
Hi Darren
For starters haven't used any of the lathes you are talking about.
Be interesting to see what the Nano goes for.
Do you want to cut threads?
The AL_30 isnt much cheaper than the AL-50 once you add a 4 jaw and faceplate(of course if you dont have the space you dont have the space)
