Results 76 to 90 of 92
13th Oct 2011, 01:30 AM #76Dave J Guest
You got a good deal their. I plan on making a lathe stand with all draws as it saves the bending.
Dave
15th Oct 2011, 07:14 AM #77Philomath in training
- 6,541
I found an old electrical cabinet and fitted that out. The QCTP holders are sitting on some pieces of Al angle. I plan to put a shelf below to cope with some of the bigger items
15th Oct 2011, 11:40 AM #78Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
michael very nice. all those tool holders as well. do you have three chuck and what sort of lathe is that?
aaron
15th Oct 2011, 02:27 PM #79Most Valued Member
Hi Michael,
Great idea. I have a cabinet pretty much the same as that, a little smaller maybe. I might just steal a few of those ideas.
15th Oct 2011, 03:35 PM #80Philomath in training
- 6,541
Azzrock, The three chuck keys are for a 3 jaw, 4 jaw (2x) and spindle camlock. I fitted extensions to some of the keys because I couldn't get a full 360 turn next to the headstock otherwise.
The lathe is a 1957 CVA model 1A series 3 toolmaker's lathe (12x30). Bought a couple of years back as a non functioning item it's turned into a very nice lathe to use.
15th Oct 2011, 04:55 PM #81Most Valued Member
- Oct 2010
- 1,910
hi Michael . i didn't think the latthe was of that vintage. sounds great do you have any more photos of your lathe.
17th Oct 2011, 12:43 PM #82Most Valued Member
- Oct 2010
- 1,910
storing metal stock
good day everyone. ive been playing around alot in my shed . this has made me wonder how every one else. stores the machining stock.
ive basically divided it to ferrous and non ferrous.. ill take a photo. there has to be a better way
17th Oct 2011, 12:59 PM #83Most Valued Member
- 4,887
Larger diameters 65mm up and under 600/700 in length I stand vertical,longer than this I lay down.
Smaller diameters I just lay down.
17th Oct 2011, 03:51 PM #84Most Valued Member
- Oct 2010
- 1,910
thanks pipe clay how much stock do you have?
17th Oct 2011, 04:12 PM #85Most Valued Member
- Oct 2010
- 1,910
maybe i just have to much stuf not worth keeping
its neat enough at the moment but will bit stay like that.
as i said Ferris and non Ferris. and try to divide those shelves up a little.
Attachment 184768Attachment 184769
17th Oct 2011, 05:03 PM #86Most Valued Member
- 4,887
I have a reasonable amount of material on hand for what I do rangeing in size from 5mm upto 150mm in High Tensile,1020,Hollow Bar and Cast Iron most of these lengths are between 50mm long upto 800mm long with the average around 400mm,there is also a smaller quantity of Aluminium,Brass and Bronze in shorter lengths,then I have a few 300mm square x 25mm thick plates and a few pieces of 250mm and 300mm diameter chunks of solid bar around 60 to 200 mm long.
18th Oct 2011, 09:10 PM #87
Mine is in the shed. Most of it that is. The stuff that is not in the shed is somewhere else. That about covers it at this point. I don't seperate machining stock from other stock. I have a huge mess in one corner of my implement shed of mostly mild steel salvage of every shape size amd colour. Some is still leaning against the wall where it started.
Unfortunately a family of rabbits decided to build a city under the dirt floor. This city collapsed then with the rain this year filled up with water and them SWMBO's dog decided to explore the rabbit situation. Needs work.
Somewhere under this mess is a large drive shaft setup for a 32 volt generator which is long gone. The shaft, mounts, bearings and pulleys are all that is left. The shaft is about 35mm diam and about 1200mm long. I guess that would be classed as machining stock now?
29th Oct 2011, 10:22 AM #88Diamond Member
- Sep 2006
- Mallacoota,VIC,Australia
- 53
- 1,010
HI,
I've just been going through this Thread to see if there were any ideas on Faceplate Storage. I spotted Michael G's lathe is this it Michael ?. The CVA in the Picture is a 1956 model and is sourced from here Page Title . Gee it has a lot of Levers on it.All The Best steran50 Stewart
29th Oct 2011, 01:53 PM #89Philomath in training
- 6,541
Same model lathe (although a year younger) but that's not mine. That page was one that contributed to me wanting to chase one though.
I did post a thread for the more curious if you want a few more pictures - http://www.woodworkforums.com/f65/bi...-lathe-142383/
The levers aren't all that bad. The really nice one is the one at spindle height in the middle of the headstock. That's the single tooth dog clutch that enables left and right hand threads without disengaging the half nuts. Because of that one I've started threading up to shoulders without the run out groove...
29th Oct 2011, 02:40 PM #90Most Valued Member
- Oct 2010
- 1,910
interesting michael. so if were going to talk about levers we like. this isn't based on functionality like your favourite lever and in fact my favourite lever isn't even a lever its a dial or hand wheel.. the lower one at the head stock end of your lathe. i like the angle and the position.. what's it for.
aaron
Show us your lathe
By Dave J in forum METALWORK GENERALReplies: 188Last Post: 25th Sep 2012, 06:09 PM -
CTC Tooling
By krisfarm in forum METALWORK GENERALReplies: 9Last Post: 27th Mar 2010, 10:53 PM -
Lathe Tooling
By glock40sw in forum METALWORK GENERALReplies: 10Last Post: 13th Aug 2007, 08:39 AM
