Results 1 to 15 of 15
Thread: Tool & cutter work of art
1st May 2011, 08:39 PM #1Product designer retired
- Nov 2006
- Heidelberg, Victoria
- 79
- 2,074
It never ceases to amaze me how clever some blokes are, especially the engineering kind. Take a look at this home made work of art.
Tool and Cutter Grinder - The Home Shop Machinist & Machinist's Workshop Magazine's BBS
Anyone got some plans for a simple unit?
Ken
1st May 2011, 10:20 PM #2Most Valued Member
- 4,890
Ken dont take this the wrong way but the best plans you could have at the moment is to get you machines running so that you can actually attempt these jobs.
2nd May 2011, 08:53 AM #3Most Valued Member
- 4,258
I found this one some time back
and it does'nt look simple to me...but what would I know..
2nd May 2011, 09:30 AM #4.
- 6,459
That should keep Ken going for a while. In the meantime, I'll take it on a thumb drive to Office Works for a bit of cheap printing. Thank you Eskimo.
2nd May 2011, 09:40 AM #5Most Valued Member
- 4,258
I've got another one on the hard drive/s... somewhere..... but I cant find it
the bigger the disk or the more drives you have is just like having a big or bigger garage...you can store more stuff ....but ya can never find anything when you want it...and when you do its always in the last spot you look
2nd May 2011, 10:26 AM #6Most Valued Member
- 70
- 1,514
2nd May 2011, 03:50 PM #7New Member
- Nov 2004
- 4
lol, also why would you keep looking if you found it? Hence it will always be in the last place you look heh heh
2nd May 2011, 04:52 PM #8Most Valued Member
- 70
- 1,514
It sometimes happens, that the last spot you looked was where it was, but you didn't see it, so therefore you keep looking and finally find it in a previous place you looked, which then becomes the last place you looked.
Done that just recently looking for some parts to a lathe.
Nev
2nd May 2011, 08:21 PM #9
Here is a link to the web site of the guy behind the Bonelle.
Design is intended to be fabricated and machined to avoid the need to procure casting sets (rarish and expensive), but there is a bucket load of machining involved.
2nd May 2011, 09:00 PM #10Member
- Jul 2007
- Melton
- 73
Hi all
Could make a Tool and Cutter Grinder out of a old car valve grinder.
got one in the work shop will look at it later this week.
Tony
2nd May 2011, 09:16 PM #11.
- 6,459
Puzzled.
I was just looking at Mr Willis' photos of his grinder and I'm still shaking my head After going to all that trouble, why would you mount a nasty switch enclosure smack bang on the front of such a beautifully crafted machine? Surely something more subtle would have been available. In my opinion, all too often switchgear looks like an afterthought.
BT
2nd May 2011, 09:19 PM #12Product designer retired
- Nov 2006
- 79
- 2,074
Ant,
That would be thinking outside the square. Now there will be a rush for old car valve grinders.
Ken
2nd May 2011, 09:51 PM #13I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 39
- 1,300
Yep - had that thought before too. Unfortunately, not often to be found cheap if you don't already have one - I check Ebay every now and then for them, but they always get pretty good money. If you managed to pick one up with all the bits and pieces though, it would be pretty easy to convert it I reckon - wonder if the boss would miss his
*edit* Perfect example of what I mean by good money - here's one needing repairs, and its still at $500 with 2 days left....
http://cgi.ebay.com.au/BLACK-AND-DEC...item3cb76929f5
3rd May 2011, 04:05 PM #14Member
- Jul 2007
- Melton
- 73
Hi all
And that one on Ebay has been droped,
And its up to $500 +…..???????
I have got 2 , one W/Brown 212 seies very good condition had it for 20 years.
No 2 is 242 series pick up for $700 8 years ago BUT half way thought rebuilding it got a price on the workhead assembly $2,500. WORK stoped on it.
WB sold all there parts to CVO in Thomastown .
Good ones go for $1,500 to $2,500
Its under the work bench when I get time to pull out will look at it to see if it can be done.
Tony
3rd May 2011, 09:24 PM #15
I like that ,he has done a great job building it.
I have been thinking of doing a t&C grinder for a while and one of the first things I was looking at using is some hydraulic cylinder shaft for the main bars and those linear bearing blocks. Much better than bushes I think. The vertical lathe add on milling slides slides are readily available and not that expensive .
He doesn't say what he used for the man spindle which is one of the very important parts .
I bought one of these some time back ,and though I may be able to utilise it for a T&C later down the track .
Thing is my collection of blunt milling cutters is growing all the while.
Kev."Outside of a dog a book is man's best friend ,inside a dog it's too dark to read"
Groucho Marx
Tool and cutter grinder
By 12teethperinch in forum THE HERCUS AREAReplies: 0Last Post: 3rd Nov 2010, 03:49 PM -
Tool & Cutter Grinder
By graemet in forum METALWORK GENERALReplies: 14Last Post: 20th Nov 2009, 08:27 AM -
Tool and Cutter grinder on eBay
By GeoffW1 in forum METALWORK GENERALReplies: 5Last Post: 22nd Mar 2009, 09:20 PM -
Tool and cutter grinder plans.
By steran50 in forum METALWORK GENERALReplies: 8Last Post: 2nd Mar 2009, 04:54 PM
