Results 1 to 5 of 5
30th Apr 2011, 05:23 PM #1Most Valued Member
- 4,890
Comparison or opinions on face mill.
Could any one who has either or both of the following let me know if one performs better than the other.,or similar.
A round insert Face mill 50 to 80mm diameter and the 45 degree Face mill of similar size.
More so interested in how often you may have to index the round insert,and also if there is any great concern with depth of cut/vibration.
Either of these will be used on an HM35.
I need to rough a few jobs shortly and was just interested in the Pros and Cons,thankyou.
30th Apr 2011, 07:29 PM #2Dave J Guest
I don't have either ones, only a smaller 45 degree cutter (about 32mm) Mark bought a round insert one and posted the results up with pictures here in the import thread I think it was.
It;'s only my opinion, but I think the 45 degree one would work better for roughing. I have read the round insert are great for profiling on the lathe.
Dave
1st May 2011, 12:34 AM #3Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
im now the proud owner of a 100mm seco face cutter . it has square inserts. i haven't used it yet
1st May 2011, 12:36 AM #4
Hi Dave, Pipeclay,
I don't have either, my facemill has the rhombic(?) shaped cutters, but i'd expect the round cutters to be a bit less prone to chipping, (no sharp corners) and you'd get more rotations, in smaller steps, so you'd use more of the cutter.
Interesting question.
1st May 2011, 04:46 AM #5Most Valued Member
- Oct 2010
- 1,910
here is my first face mill.
i can see the advantage if this one. im hoping the tips wont were so quick
Attachment 168648
Attachment 168649
Face Mill Arbor Question. CTC?
By Greg Q in forum METALWORK GENERALReplies: 7Last Post: 1st Feb 2011, 05:52 PM -
CTC Face Mill - Any Users?
By Anorak Bob in forum METALWORK GENERALReplies: 61Last Post: 6th Jan 2011, 01:41 PM -
50mm Face Mill and 10 Mitsubishi Inserts for $CHEAP
By markjaffa in forum METALWORK GENERALReplies: 18Last Post: 11th Sep 2010, 02:23 PM -
Face Mill V End Mill
By eskimo in forum METALWORK GENERALReplies: 8Last Post: 31st Aug 2010, 03:19 AM
