Results 1 to 4 of 4
Thread: herless h 35768 drill
1st Apr 2011, 07:38 PM #1Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
hi im not shore how to describe this drill the only marking i can see are herless h35768
its a geared head drill with a tapping function.
top speed i think of 900 rpm. ill post a photo tom.
it doesn't look all that differant from photos of milld ive seen on here.
except for no mill table. it has got me thinking maybe i can turn this drill
into my own mill.
1st Apr 2011, 08:23 PM #2Dave J Guest
The problem you will have is holding something in the MT if if doesn't have provision for a draw bar. If it does your fine but if not you may be able to thread the end of the spindle and make a nut for it like the Arboga mill drill
http://www.woodworkforums.com/f65/ar...ml#post1292159
If you can get over that problem, buy a compound table and you should be right to go.
Dave
1st Apr 2011, 08:30 PM #3Most Valued Member
- Oct 2010
- 1,910
i had thought of that no draw bar. its prob a 3mt. im going to have a look tom. and then hope they will give it to me. im shore its been 15 od years since any one plugged it in.
1st Apr 2011, 08:39 PM #4Most Valued Member
- Oct 2010
- 1,910
i think it is very similar in size and shape. speed change levers on the other side. aswell as some other controls to do with feed i think.
Herless BM-450A or Hafco TC-450 T&C Instructions Wanted
By steran50 in forum METALWORK GENERALReplies: 4Last Post: 1st Nov 2010, 07:35 PM -
Herless Lathes
By Bidgee in forum METALWORK GENERALReplies: 9Last Post: 17th Jul 2009, 12:05 PM
